<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.008" expanded="true" name="Process"> <process expanded="true" height="607" width="747"> <operator activated="true" class="generate_data" compatibility="5.1.008" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="number_of_attributes" value="2"/> <parameter key="attributes_lower_bound" value="0.0"/> <parameter key="datamanagement" value="int_array"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.008" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="sort" compatibility="5.1.008" expanded="true" height="76" name="Sort" width="90" x="313" y="30"> <parameter key="attribute_name" value="att2"/> </operator> <operator activated="true" class="sort" compatibility="5.1.008" expanded="true" height="76" name="Sort (2)" width="90" x="447" y="30"> <parameter key="attribute_name" value="att1"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Sort" to_port="example set input"/> <connect from_op="Sort" from_port="example set output" to_op="Sort (2)" to_port="example set input"/> <connect from_op="Sort (2)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
