RapidMiner.setExecutionMode(ExecutionMode.EMBEDDED_WITHOUT_UI); // or whatever you needRapidMiner.init();IOContainer ioResult = process.run();IOObject result = ioResult.getElementAt(0); // or whatever index you needString name = RendererService.getName(result.getClass());List<Renderer> renderers = RendererService.getRenderers(name);for (Renderer renderer : renderers) { // you don't really need to iterate over this, it's probably only one anyway IOContainer dummy = new IOContainer(); int imgWidth = 300; int imgHeight = 300; Reportable reportable = renderer.createReportable(result, dummy, imgWidth, imgHeight); if (reportable instanceof Renderable) { Renderable renderable = (Renderable) reportable; renderable.prepareRendering(); int preferredWidth = renderable.getRenderWidth(800); int preferredHeight = renderable.getRenderHeight(800); final BufferedImage img = new BufferedImage(imgWidth, imgHeight, BufferedImage.TYPE_INT_RGB); Graphics2D graphics = (Graphics2D) img.getGraphics(); graphics.setColor(Color.WHITE); graphics.fillRect(0, 0, imgWidth, imgHeight); double scale = Math.min((double) imgWidth / (double) preferredWidth, (double) imgHeight / (double) preferredHeight); graphics.scale(scale, scale); renderable.render(graphics, preferredWidth, preferredHeight); }}
ImageIO.write(img,”png”,out);
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="parallelize_main_process" value="false"/> <process expanded="true" height="161" width="279"> <operator activated="true" class="retrieve" compatibility="5.2.003" expanded="true" height="60" name="Retrieve" width="90" x="45" y="75"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="decision_tree" compatibility="5.2.003" expanded="true" height="76" name="Decision Tree" width="90" x="179" y="75"> <parameter key="criterion" value="gain_ratio"/> <parameter key="minimal_size_for_split" value="4"/> <parameter key="minimal_leaf_size" value="2"/> <parameter key="minimal_gain" value="0.1"/> <parameter key="maximal_depth" value="20"/> <parameter key="confidence" value="0.25"/> <parameter key="number_of_prepruning_alternatives" value="3"/> <parameter key="no_pre_pruning" value="false"/> <parameter key="no_pruning" value="false"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
package com.testpackage;import java.awt.Color;import java.awt.Graphics2D;import java.awt.image.BufferedImage;import java.io.IOException;import java.util.List;import javax.swing.ImageIcon;import javax.swing.JFrame;import javax.swing.JLabel;import javax.swing.JScrollPane;import com.rapidminer.Process;import com.rapidminer.RapidMiner;import com.rapidminer.RapidMiner.ExecutionMode;import com.rapidminer.RepositoryProcessLocation;import com.rapidminer.gui.renderer.Renderer;import com.rapidminer.gui.renderer.RendererService;import com.rapidminer.operator.IOContainer;import com.rapidminer.operator.IOObject;import com.rapidminer.operator.OperatorException;import com.rapidminer.report.Renderable;import com.rapidminer.report.Reportable;import com.rapidminer.repository.Entry;import com.rapidminer.repository.ProcessEntry;import com.rapidminer.repository.RepositoryException;import com.rapidminer.repository.RepositoryLocation;import com.rapidminer.tools.XMLException;public class PlotterTest { public static void main(String[] args) { RapidMiner.setExecutionMode(ExecutionMode.EMBEDDED_WITHOUT_UI); RapidMiner.init(); JFrame frame = new JFrame("Decision Tree Renderer Test"); frame.setLocation(0, 0); JLabel label = new JLabel(); frame.add(new JScrollPane(label)); try { RepositoryLocation location; RapidMiner.setExecutionMode(ExecutionMode.COMMAND_LINE); RapidMiner.init(); location = new RepositoryLocation("//LocalRepository/Test/DecTree"); Entry entry = location.locateEntry(); if (entry instanceof ProcessEntry) { Process process = new RepositoryProcessLocation(location).load(null); IOContainer ioResult = process.run(); IOObject result = ioResult.getElementAt(0); // or whatever index you need String name = RendererService.getName(result.getClass()); List<Renderer> renderers = RendererService.getRenderers(name); for (Renderer renderer : renderers) { // you don't really need to // iterate over this, it's // probably only one anyway // IOContainer dummy = new IOContainer(); // edit size of image here int imgWidth = 1600; int imgHeight = 950; Reportable reportable = renderer.createReportable(result, dummy, imgWidth, imgHeight); if (reportable instanceof Renderable) { Renderable renderable = (Renderable) reportable; renderable.prepareRendering(); int preferredWidth = renderable.getRenderWidth(800); int preferredHeight = renderable.getRenderHeight(800); final BufferedImage img = new BufferedImage(imgWidth, imgHeight, BufferedImage.TYPE_INT_RGB); Graphics2D graphics = (Graphics2D) img.getGraphics(); graphics.setColor(Color.WHITE); graphics.fillRect(0, 0, imgWidth, imgHeight); // scale to whatever you need graphics.scale(2, 2); renderable.render(graphics, preferredWidth, preferredHeight); label.setIcon(new ImageIcon(img)); } } } } catch (IOException e) { // TODO Auto-generated catch block e.printStackTrace(); } catch (XMLException e) { // TODO Auto-generated catch block e.printStackTrace(); } catch (OperatorException e) { // TODO Auto-generated catch block e.printStackTrace(); } catch (RepositoryException e) { // TODO Auto-generated catch block e.printStackTrace(); } frame.setVisible(true); frame.pack(); frame.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE); }}
