<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.006" expanded="true" name="Process"> <process expanded="true" height="100" width="145"> <operator activated="true" class="read_sparse" compatibility="5.1.006" expanded="true" height="60" name="Read Sparse" width="90" x="45" y="30"> <parameter key="format" value="yx"/> <parameter key="data_file" value="C:\Users\Ingo Mierswa\Desktop\a1a.dat"/> <parameter key="dimension" value="123"/> <list key="prefix_map"/> </operator> <connect from_op="Read Sparse" from_port="output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
