Hello All,
I am doing LS Dyna to Nastran/Optistruct conversion job (Modal analysis set up only). I want to convert the CONM2 (mass)elements units (ton --> kg). Is there any easy and less time consuming way to do that (using Macro etc.,)?
Since this original LS Dyna version is created using some other software, the mass distribution is varying among the nodes (which means each node have different additional mass), I cannot able to update the mass elements with 1d--> masses-->update option (also there are more than 1000 mass elements)
Thanks,
Udhay
