I know this is a very simple question but I'm not able to select only the non-special attributes of a ExampleSet in a simple way.
Obviusly I can select manually the special attributes and apply the correct filter but that's the problem: I need to know the roles of the attributes. If I'd like to do it with 8 different samples (tables) I'd have to look for the special attributes in each sample and apply the filter with the correct names of the special attributes. There must be an easier way.
Some help?
I Tried to use the "Select Attibutes" filter but it select all the attributes or only the special ones but not only the regulars.
Thanks in advance.
<process version="5.1.004">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" breakpoints="before" class="process" compatibility="5.1.004" expanded="true" name="Process">
<process expanded="true" height="524" width="435">
<operator activated="true" breakpoints="before,after" class="generate_data" compatibility="5.1.004" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/>
<operator activated="true" breakpoints="after" class="generate_id" compatibility="5.1.004" expanded="true" height="76" name="Generate ID" width="90" x="179" y="30"/>
<operator activated="true" breakpoints="before" class="select_attributes" compatibility="5.1.004" expanded="true" height="76" name="Select Attributes" width="90" x="315" y="30"/>
<connect from_op="Generate Data" from_port="output" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/>
</process>
</process>
