<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.008" expanded="true" name="Process"> <process expanded="true" height="145" width="279"> <operator activated="true" class="retrieve" compatibility="5.1.008" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="expectation_maximization_clustering" compatibility="5.1.008" expanded="true" height="76" name="Clustering" width="90" x="179" y="30"> <parameter key="k" value="30"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_port="result 1"/> <connect from_op="Clustering" from_port="clustered set" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
