Hello!
I developed a process that consists of the following steps:
1) Read dataset
2) Split in test and training set
3) Do a feature selection in the training set using SVM, Foward selection, X-Val and OptimizeParameters
4) Build a model using the selected parameters
4) Apply the resulting model (that is, the one generated with the best features) to the test set
The problem is that SVM classifiers expect that the test set has exactly the same features that were used to build the model, otherwise the results are screwed up. But I did not manage to filter out the features of the test set that were not among the selected ones.
Stating more concisely, given two
different datasets A and B, where the features of B consists of a
subset of the features of A, I need a dataset C that consist of the data contained in A but
comprising only the features shared with B:
Dataset A
| ID | Feature 1 | Feature 2 | Feature 3 |
| 1 | 3 | 9 | 2 |
| 2 | 5 | 3 | 1 |
Dataset B
| ID | Feature 1 | Feature 3 |
| 35 | 1 | 0 |
| 41 | 2 | 9 |
| 29 | 2 | 9 |
Dataset C
| 1 | 3 | 2 |
| 2 | 5 | 1 |
I am doing things this way (instead of using only X-Val) so as to guarantee that my test set is not used at all during the modelling process.
If somebody has some clue of how doing this (or if I should do it another way) I will thank a lot!
Best regards,
Vinicius
