<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.001" expanded="true" name="Process"> <process expanded="true" height="145" width="279"> <operator activated="true" class="retrieve" compatibility="5.1.001" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="write_special" compatibility="5.1.001" expanded="true" height="60" name="Write Special Format" width="90" x="179" y="30"> <parameter key="example_set_file" value="C:\Users\Ingo\Desktop\sparse_result.txt.dat"/> <parameter key="special_format" value="$s[;][:]"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Write Special Format" to_port="input"/> <connect from_op="Write Special Format" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
