rapidanalytics reporting
kljosc
I'm evaluating mining applications and tried rapidanalytics. A job with a report generated (extension installed) in rapidminer runs without problems, but when I run it in rapidanalytics I get an error (com.rapidminer.operator.UserError: The dummy operator Generate Report (replacing reporting:generate_report) cannot be executed.)
Do I have to install/copy the reporting extension to rapidanalytics?
Thx
Klemens
Server
Dmitriy
Yep, just copy the extension file (.jar) into the plugins directory you have specified during your RapidAnalytics installation. And then restart server.
Good Luck.
kljosc
Hmm...
I copied the files to the plugins directory and the logfile says, that it finds the jars, but doesn't load the extensions.
-- snip --
20:44:11,546 CONFIG [rapidminer] Registering Plugins
20:44:11,546 CONFIG [rapidminer] Scanning plugins in W:\rapidanalytics\bin\plugins.
20:44:11,677 WARNING [rapidminer] The jar file 'W:\rapidanalytics\bin\plugins\jfreechart.jar' does not contain an entry 'RapidMiner-Type' in its manifest and will therefore not be loaded (if this file actually is a plugin updating the plugin file might help).
-- snip --
Any ideas?
Dmitriy
May be you copied a wrong files?
Try to download from here and do it again:
http://sourceforge.net/projects/rapidminer/files/2.%20Extensions/
kljosc
Hi an thanks
I copied the files now and the log shows correct loading of the extensions, but when I try to run the job it shows this error again
fischer
I can't believe that yet :-) When you go to the admin console, can you check "Administration" / "Operators & Extensions" to see whether the reporting ops are there at all?
Best,
Simon
