Torsional stiffness of solid shaft (angular disp. of solid elements)
Hello everyone,
I have a solid shaft to which I am applying torque and have to find the torsional stiffness of the same.
But I have read that we can not find out the angular deformation of solid elements. So how to measure it in optistruct? Or do I have to use the method of dividing the obtained displacement by radius?
Regards
Bharat Hiranwale
You can compute from nodal displacement by dividing by radius from reference point.
0 -
thank you for the reply.
0 -
Hi
another way is assign the shaft into a cylindrical system, so deform 'y' will be angle
0 -
Hi
Yeah, it's better way /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
0 -
Hi
Hello tinh,
Thanks for the reply.
Can you please explain how can I define the cylindrical csys?
Bharat
0 -
Thank you very much Prakash.
Bharat
