Please anyone? How to get Precision Recall curves for every fold in CV
John_De_Jong
John_De_Jong New Altair Community Member
:'(Folks
I may sound desperate, but tried everything. Can any of the gurus tell me or reply to my earlier email on how to get Precision Recall curves for every fold in CV evaluation. I have to get Precision Recall cruves instead of ROC curves, i couldnt find it in manual, forum and along with another student have asked 3 times, can someone tell me it is possible and show me in the code below how can be done?
Please thanks
Johan!
process version="5.1.001">
 <context>
   <input/>
   <output/>
   <macros/>
 </context>
 <operator activated="true" class="process" compatibility="5.1.001" expanded="true" name="Process">
   <parameter key="parallelize_main_process" value="false"/>
   <process expanded="true" height="500" width="752">
     <operator activated="true" class="retrieve" compatibility="5.1.001" expanded="true" height="60" name="Retrieve" width="90" x="17" y="58">
       <parameter key="repository_entry" value="Acceptor3KData"/>
     <operator activated="true" class="set_role" compatibility="5.1.001" expanded="true" height="76" name="Set Role" width="90" x="112" y="165">
       <parameter key="name" value="class"/>
     <operator activated="true" class="replace" compatibility="5.1.001" expanded="true" height="76" name="Replace" width="90" x="313" y="210">
       <parameter key="attribute" value="class"/>
       <parameter key="value_type" value="nominal"/>
       <parameter key="except_value_type" value="file_path"/>
       <parameter key="block_type" value="single_value"/>
       <parameter key="except_block_type" value="single_value"/>
       <parameter key="replace_what" value="[0]"/>
       <parameter key="replace_by" value="1"/>
     <operator activated="true" class="x_validation" compatibility="5.1.001" expanded="true" height="130" name="Validation" width="90" x="447" y="75">
       <parameter key="create_complete_model" value="false"/>
       <parameter key="average_performances_only" value="false"/>
       <parameter key="leave_one_out" value="false"/>
       <parameter key="number_of_validations" value="5"/>
       <parameter key="sampling_type" value="stratified sampling"/>
       <parameter key="use_local_random_seed" value="false"/>
       <parameter key="local_random_seed" value="1992"/>
       <parameter key="parallelize_training" value="false"/>
       <parameter key="parallelize_testing" value="false"/>
       <process expanded="true" height="500" width="351">
         <operator activated="true" class="fast_large_margin" compatibility="5.1.001" expanded="true" height="76" name="Fast Large Margin" width="90" x="130" y="110">
           <parameter key="solver" value="L2 SVM Dual"/>
           <parameter key="C" value="1.0"/>
           <parameter key="epsilon" value="0.01"/>
           <list key="class_weights"/>
           <parameter key="use_bias" value="true"/>
         <connect from_port="training" to_op="Fast Large Margin" to_port="training set"/>
         <connect from_op="Fast Large Margin" from_port="model" to_port="model"/>
         <portSpacing port="source_training" spacing="108"/>
       </process>
         <operator activated="true" class="apply_model" compatibility="5.1.001" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
           <parameter key="create_view" value="false"/>
         <operator activated="true" class="performance_binominal_classification" compatibility="5.1.001" expanded="true" height="76" name="Performance" width="90" x="179" y="30">
           <parameter key="main_criterion" value="accuracy"/>
           <parameter key="accuracy" value="true"/>
           <parameter key="classification_error" value="true"/>
           <parameter key="kappa" value="true"/>
           <parameter key="AUC (optimistic)" value="true"/>
           <parameter key="AUC" value="true"/>
           <parameter key="AUC (pessimistic)" value="true"/>
           <parameter key="precision" value="true"/>
           <parameter key="recall" value="true"/>
           <parameter key="lift" value="false"/>
           <parameter key="fallout" value="false"/>
           <parameter key="f_measure" value="true"/>
           <parameter key="false_positive" value="true"/>
           <parameter key="false_negative" value="true"/>
           <parameter key="true_positive" value="true"/>
           <parameter key="true_negative" value="true"/>
           <parameter key="sensitivity" value="true"/>
           <parameter key="specificity" value="true"/>
           <parameter key="youden" value="false"/>
           <parameter key="positive_predictive_value" value="true"/>
           <parameter key="negative_predictive_value" value="true"/>
           <parameter key="psep" value="false"/>
           <parameter key="skip_undefined_labels" value="true"/>
           <parameter key="use_example_weights" value="true"/>
         <operator activated="true" class="log" compatibility="5.1.001" expanded="true" height="76" name="Log" width="90" x="179" y="165">
           <parameter key="filename" value="C:\Output.log"/>
           <list key="log">
             <parameter key="recall" value="operator.Validation.value.performance1"/>
             <parameter key="precision" value="operator.Validation.value.performance2"/>
           </list>
           <parameter key="sorting_type" value="none"/>
           <parameter key="sorting_k" value="100"/>
           <parameter key="persistent" value="true"/>
         <connect from_port="model" to_op="Apply Model" to_port="model"/>
         <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
         <connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
         <connect from_op="Log" from_port="through 1" to_port="averagable 2"/>
         <portSpacing port="sink_averagable 1" spacing="0"/>
         <portSpacing port="sink_averagable 2" spacing="0"/>
         <portSpacing port="sink_averagable 3" spacing="0"/>
       </process>
     <connect from_op="Retrieve" from_port="output" to_op="Set Role" to_port="example set input"/>
     <connect from_op="Set Role" from_port="example set output" to_op="Replace" to_port="example set input"/>
     <connect from_op="Replace" from_port="example set output" to_op="Validation" to_port="training"/>
     <connect from_op="Validation" from_port="training" to_port="result 1"/>
     <connect from_op="Validation" from_port="averagable 1" to_port="result 2"/>
   </process>
</process>
  • land
    land New Altair Community Member
    Hi again,
    Sorry for your inconvenience but, take a look at my previous answers to your previous posts...
    Greetings,
      Sebastian
