Folks
I created a process to Retrieve Data and Perform Cross Validation using Fast Margin Classifier. My process definition is below. I wanted to know how to
1. log Precision, Recall points so that can be plotted using external software. I did use log operator but somehow only the precision, recall values are printed not for each instance.
2. Ability to get auPRC metric from the process.
Maybe there is some mistake in what i am doing, so any help from experts here is appreciated
Thanks
Johan
<process version="5.1.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.001" expanded="true" name="Process">
<process expanded="true" height="500" width="752">
<operator activated="true" class="retrieve" compatibility="5.1.001" expanded="true" height="60" name="Retrieve" width="90" x="17" y="58">
<parameter key="repository_entry" value="Acceptor3KData"/>
<operator activated="true" class="set_role" compatibility="5.1.001" expanded="true" height="76" name="Set Role" width="90" x="112" y="165">
<parameter key="name" value="class"/>
<operator activated="true" class="replace" compatibility="5.1.001" expanded="true" height="76" name="Replace" width="90" x="313" y="210">
<parameter key="attribute" value="class"/>
<parameter key="replace_what" value="[0]"/>
<parameter key="replace_by" value="1"/>
<operator activated="true" class="x_validation" compatibility="5.1.001" expanded="true" height="130" name="Validation" width="90" x="447" y="75">
<parameter key="number_of_validations" value="5"/>
<process expanded="true" height="500" width="351">
<operator activated="true" class="fast_large_margin" compatibility="5.1.001" expanded="true" height="76" name="Fast Large Margin" width="90" x="130" y="110">
<list key="class_weights"/>
<connect from_port="training" to_op="Fast Large Margin" to_port="training set"/>
<connect from_op="Fast Large Margin" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="108"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.1.001" expanded="true" height="76" name="Apply Model" width="90" x="63" y="25">
<operator activated="true" class="performance_classification" compatibility="5.1.001" expanded="true" height="76" name="Performance" width="90" x="179" y="30">
<parameter key="main_criterion" value="weighted_mean_recall"/>
<parameter key="accuracy" value="false"/>
<parameter key="weighted_mean_recall" value="true"/>
<parameter key="weighted_mean_precision" value="true"/>
<operator activated="true" class="log" compatibility="5.1.001" expanded="true" height="76" name="Log" width="90" x="179" y="165">
<parameter key="filename" value="C:\Output.log"/>
<list key="log">
<parameter key="recall" value="operator.Validation.value.performance1"/>
<parameter key="precision" value="operator.Validation.value.performance2"/>
</list>
<parameter key="persistent" value="true"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<connect from_op="Log" from_port="through 1" to_port="averagable 2"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
<portSpacing port="sink_averagable 3" spacing="0"/>
</process>
<connect from_op="Retrieve" from_port="output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Replace" to_port="example set input"/>
<connect from_op="Replace" from_port="example set output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="training" to_port="result 1"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 2"/>
</process>
</process>
