Altair RISE
Nominate Yourself Now!
Extract coefficients from linear regressions Model
User: "Matthias"
New Altair Community Member
Updated by Jocelyn
Hi all,
I 've to extract the coefficients from a linear regressions Model. I want solve this with a little java script, following this topic
http://rapid-i.com/rapidforum/index.php/topic,2427.0.html
First I want to input the model with
IOObject ioobject = operator.getInput(IOObject.class);
However I don't know how to transform the IOObject into a LinearRegressionsModel so that I can use the getCoefficients() command.
Would be nice if someone has an idea
Greetings
Matthias
1 - 2 of 21
    User: "land"
    well actually casting would be a good idea. But if you aren't a Java freak, I would recommend using a simple operator for that: The coefficients are returned as weight Vector from the Linear Regression itself. So you can use it or transform it to a data set using Weights to Data. Then you can save it in any format you want. No coding needed at all...
    Greetings,
      Sebastian
    User: "Matthias"
    OP
    I don't know exactly why I didn't see the Output port for the weight vector all the time, but you are right there is one.
    Thanks
    Matthias
