Material definition in Radioss
Hello everyone,
In radioss ,while defining material there are lot of property options are present. But what if I don,t have properties available apart from E, density, Poisson's ratio and stress strain curve. How do I define material correctly then. I am trying for rubber materials.
Bharat
Hi Bharat,
In your case you can use MAT/LAW 36 for the properties which you. Rest you can leave it default.
0 -
Thank you Prakash for the help.
Bharat
0 -
I have one query about applying material property. Suppose if a material data doesn't have yield limit and it has only ultimate tensile strength how can we define it in the curve ? It is Nylon product so i have used LAW 36
0 -
For /MAT/LAW36, the elastic portion of the material is defined by Young modulus and Poisson’s ratio where as the plastic behavior is defined by the stress-strain curve.
And the curve should start from the yield point value, in short the curve should have post yield values.
For your case you can try with /MAT/LAW65 (ELASTOMER), where user has to provide the full stress-strain curve.
0 -
207 is the tensile strength of the material, that is the ultimate strength a member can carry but when you define as this in /MAT/LAW36 207 becomes the yield strength and it breaks at a very close value to yield, behaving something like a brittle material.
I'm not sure whether this will give you the proper results.
0 -
Ya i am also having the same concern. So for these kind of materials which material card i need to use ?
0 -
As suggested above you can try with /MAT/LAW65 (ELASTOMER) for nylon but user has to provide the full stress-strain curve.
0 -
Thanks george.
What is the difference between LAW36 and LAW65. Both are elastic-plastic behavior card right ?
0 -
In LAW36 user has to provide the stress-strain function from post yield values, so that it defines the plastic behavior of the material.
Whereas in LAW65 for the material behavior user has to provide the full stress-strain curve, and I feel that for your purpose this material law will serve the purpose.
