Ingo Mierswa wrote:Hi Pablo,you are right: from an algorithmic point of view there is currently no difference between "polynominal" and "nominal". As far as I know, all operators which can handle one of both can automatically handle both (please correct me somebody if I forgot an operator where this would indeed make a difference). But who knows: Maybe there is such a difference later on for a new operator and the used ontology can be seen as a preparation for that. However, in today's practical processses you will be perfectly fine by using one of both options and just make sure that all operators are happy The same is true for numerical value types although I think that there actually are (or at least: was) some algorithm which really has relied on the fact that the input has to be "real" instead of "numerical"...Cheers,Ingo
Ingo Mierswa wrote:Hi Pablo,you are right: from an algorithmic point of view there is currently no difference between "polynominal" and "nominal". As far as I know, all operators which can handle one of both can automatically handle both (please correct me somebody if I forgot an operator where this would indeed make a difference). [...]Cheers,Ingo
