"comparing decision trees"
Hi! I'm generating decision trees varying input parameters: criterium, maximal depth and confidence. For comparing the different decision trees obtained i'm mostly considering:
-Accuracy
-Precision
-Recall
-Class Frequencies, because i'm interested in the most frequently classes obtained.
But Rapid Miner offers for example 4 criteria ( gain_ratio, information_gain, gini_index, accuracy) for Decision Tree (i'm not working with Multy way decision tree, or with weight based, ID3 or CHAID). Each of them generates trees with different class frequencies, accuracy, recall and precision.
I was wondering if there is some kind of framework for comparing this trees. For example i can obtain classes with high frequencies but not so high Precision, or lower frequencies and higher accuracy, how can these trees be compared?
Regarding the usability of the obtained results:
If following a branch of the tree i get some frequency but following another i get a slightly higher frequency involving more variables maybe this last one is better because it's more informative but how could i compare them? which branch is "better" if they are all slightly different? or all of them are quite similar regarding frequency?
Thanks
Karen
