Stress strain curve for compression and tension of rubber
hiranwale_bharat
hiranwale_bharat Altair Community Member
Hello Everyone,
I have tension and compression stress strain data for rubber material. If my component is going through tension as well as compression loading, can I create a stress strain curve starting from compressive (third ) quadrant and then continuing it to tensile(first) quadrant? Or is there any other method for defining material for compression as well as tensile loads?
Bharat
  • Altair Forum User
    Altair Forum User
    edited August 2015
    Hi Bahrat,
    You can use TABLES1 card to use Stress-Strain curve.
    One rule for this to work is the x should be either increasing or decreasing.
  • hiranwale_bharat
    edited August 2015
    Hello Prakash,
    Yes I have thought of this concept. I hope it works for my problem.
    Thanks and Regards,
    Bharat
Welcome!
Welcome!
