"Community edition install issue"
slg
I installed RM community edition on a Win7 PC that is a member of a exchange domain. It installed ok, but doesn't run... When I login to the same machine under a work-group account it seems to work ok. Is there something that you can think of that explains this behavior? Thanks in advance!
Installation
land
this sounds like you have problems with your user rights. Might be you could ask your administrator if there is some group policy that prevents you from starting RapidMiner or other Java Programs.
A more detailed problem description could also help a lot. Try to execute the Command Line version of RapidMiner and post the log here. The Command line version should be added to the start menu group as well.
Greetings,
Sebastian
slg
Thanks for your reply. The account that is running the app. is unrestricted (in the admin group), but it is quite possible that some group policy issues are causing this... When running in console I noticed that it loops.. so I had to make a guess when I took the following snapshot...
Thanks again!
Simon
RAPIDMINER_HOME is not set. Trying the directory 'C:\Program Files\Rapid-I\Rapid
Miner5\scripts\..'...
Using local jre: C:\Program Files\Rapid-I\RapidMiner5\scripts\..\jre\bin\java.ex
e...
Starting RapidMiner from 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..' using
classes from 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..\lib\rapidminer.ja
r'...
Mar 2, 2011 5:01:16 AM com.rapid_i.Launcher ensureRapidMinerHomeSet
INFO: rapidminer.home is 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..'.
Mar 2, 2011 5:01:17 AM com.rapid_i.Launcher main
INFO: Launching RapidMiner, platform WIN32
2011-03-02 05:01:17 CONFIG: Locale not specified explicitly. Set default locale
to US. (RapidMiner.init())
2011-03-02 05:01:17 INFO: rapidminer.home is 'C:\Program Files\Rapid-I\RapidMine
r5\scripts\..'. (Launcher.ensureRapidMinerHomeSet())
2011-03-02 05:01:17 CONFIG: Reading configuration resource com/rapidminer/resour
ces/rapidminerrc. (ParameterService.loadAllRCFiles())
2011-03-02 05:01:17 CONFIG: Neither system property 'rapidminer.config.dir' nor
environment variable 'RAPIDMINER_CONFIG_DIR' not set. Ignored. (ParameterService
.getGlobalConfigDir())
2011-03-02 05:01:17 CONFIG: Trying rcfile 'C:\Users\RMUser\.RapidMiner5\5_
1_000_rapidminerrc'...skipped (ParameterService.loadRCFile())
2011-03-02 05:01:17 CONFIG: Read rcfile 'C:\Users\RMUser\.RapidMiner5\5_1_
000_rapidminerrc.Windows 7'. (ParameterService.loadRCFile())
2011-03-02 05:01:17 CONFIG: Trying rcfile 'C:\Program Files\Rapid-I\RapidMiner5\
rapidminerrc.Windows 7'...skipped (ParameterService.loadRCFile())
2011-03-02 05:01:17 CONFIG: Property rapidminer.rcfile not specified...skipped (
2011-03-02 05:01:17 CONFIG: Read extension state. (ManagedExtension.readConfigur
ation())
2011-03-02 05:01:17 CONFIG: Scanning plugins in C:\Program Files\Rapid-I\RapidMi
ner5\scripts\..\lib\plugins. (Plugin.findAndRegisterPlugins())
2011-03-02 05:01:18 CONFIG: Loading renderers from 'Text Processing'. (RendererS
ervice.init())
2011-03-02 05:01:18 CONFIG: Reading parse rules from jar:file:/C:/Users/RMUser
/.RapidMiner5/managed/rmx_text-5.0.7.jar!/com/rapidminer/resources/parserule
sTextProcessing.xml (XMLImporter.importParseRules())
2011-03-02 05:01:18 CONFIG: Loading renderers from 'PMML'. (RendererService.init
/.RapidMiner5/managed/rmx_pmml-5.0.2.jar!/com/rapidminer/resources/parserule
sPMML.xml (XMLImporter.importParseRules())
2011-03-02 05:01:18 CONFIG: Loading renderers from 'Weka'. (RendererService.init
/.RapidMiner5/managed/rmx_weka-5.0.1.jar!/com/rapidminer/resources/parserule
sWekaExtension.xml (XMLImporter.importParseRules())
2011-03-02 05:01:18 CONFIG: Loading renderers from 'R Extension'. (RendererServi
ce.init())
/.RapidMiner5/managed/rmx_r-5.0.2.jar!/com/rapidminer/resources/parserulesR.
2011-03-02 05:01:18 CONFIG: Loading renderers from 'PaREn Wizard'. (RendererServ
ice.init())
/.RapidMiner5/managed/rmx_paren-5.0.1.jar!/com/rapidminer/resources/parserul
esParen.xml (XMLImporter.importParseRules())
2011-03-02 05:01:18 CONFIG: Loading renderers from 'Web Mining'. (RendererServic
e.init())
/.RapidMiner5/managed/rmx_web-5.0.4.jar!/com/rapidminer/resources/parserules
Web.xml (XMLImporter.importParseRules())
2011-03-02 05:01:18 CONFIG: Loading renderers from 'Series'. (RendererService.in
it())
/.RapidMiner5/managed/rmx_series-5.0.2.jar!/com/rapidminer/resources/parseru
lesValueSeries.xml (XMLImporter.importParseRules())
2011-03-02 05:01:18 CONFIG: Loading renderers from 'Reporting'. (RendererService
.init())
/.RapidMiner5/managed/rmx_reporting-5.0.2.jar!/com/rapidminer/resources/pars
erulesReporting.xml (XMLImporter.importParseRules())
2011-03-02 05:01:18 CONFIG: Loading operators from 'OperatorsCore.xml'. (Operato
rService.registerOperators())
2011-03-02 05:01:18 CONFIG: Loading operator documentation from jar:file:/C:/Pro
gram%20Files/Rapid-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/i1
8n/OperatorsCoreDocumentation.xml. (OperatorDocBundle$XMLControl.newBundle())
2011-03-02 05:01:22 WARNING: Password in XML file looks like unencrypted plain t
ext. (ParameterTypePassword.decryptPassword())
2011-03-02 05:01:24 CONFIG: Loading operators from 'C:\Users\RMUser\.Rapid
Miner5\managed\rmx_text-5.0.7.jar'. (OperatorService.registerOperators())
2011-03-02 05:01:24 CONFIG: Loading operator documentation from jar:file:/C:/Use
rs/RMUser/.RapidMiner5/managed/rmx_text-5.0.7.jar!/com/rapidminer/resource
s/i18n/OperatorsDocTextProcessing.xml. (OperatorDocBundle$XMLControl.newBundle()
Miner5\managed\rmx_parallel-5.0.1.jar'. (OperatorService.registerOperators())
rs/RMUser/.RapidMiner5/managed/rmx_parallel-5.0.1.jar!/com/rapidminer/reso
urces/i18n/OperatorsDocParallel.xml. (OperatorDocBundle$XMLControl.newBundle())
Miner5\managed\rmx_pmml-5.0.2.jar'. (OperatorService.registerOperators())
rs/RMUser/.RapidMiner5/managed/rmx_pmml-5.0.2.jar!/com/rapidminer/resource
s/i18n/OperatorsDocPMML.xml. (OperatorDocBundle$XMLControl.newBundle())
Miner5\managed\rmx_weka-5.0.1.jar'. (OperatorService.registerOperators())
rs/RMUser/.RapidMiner5/managed/rmx_weka-5.0.1.jar!/com/rapidminer/resource
s/i18n/OperatorsDocWekaExtension.xml. (OperatorDocBundle$XMLControl.newBundle())
2011-03-02 05:01:24 CONFIG: Creating operators from factory com.rapidminer.tools
.WekaOperatorFactory (OperatorService.parseOperators())
2011-03-02 05:01:27 CONFIG: Loading operators from 'C:\Users\RMUser\.Rapid
Miner5\managed\rmx_r-5.0.2.jar'. (OperatorService.registerOperators())
2011-03-02 05:01:27 CONFIG: Loading operator documentation from jar:file:/C:/Use
rs/RMUser/.RapidMiner5/managed/rmx_r-5.0.2.jar!/com/rapidminer/resources/i
18n/OperatorsDocR.xml. (OperatorDocBundle$XMLControl.newBundle())
2011-03-02 05:01:27 CONFIG: Creating operators from factory com.rapidminer.opera
tor.r.ROperatorFactory (OperatorService.parseOperators())
Miner5\managed\rmx_paren-5.0.1.jar'. (OperatorService.registerOperators())
rs/RMUser/.RapidMiner5/managed/rmx_paren-5.0.1.jar!/com/rapidminer/resourc
es/i18n/OperatorsDocParen.xml. (OperatorDocBundle$XMLControl.newBundle())
2011-03-02 05:01:28 INFO: No operator descriptor specified for plugin Community.
Trying plugin initializtation class com.rapidminer.community.CommunityPluginIni
t. (Plugin.registerOperators())
2011-03-02 05:01:28 WARNING: No operator descriptor defined for: Community (Plug
2011-03-02 05:01:28 CONFIG: Loading operators from 'C:\Users\RMUser\.Rapid
Miner5\managed\rmx_web-5.0.4.jar'. (OperatorService.registerOperators())
2011-03-02 05:01:28 CONFIG: Loading operator documentation from jar:file:/C:/Use
rs/RMUser/.RapidMiner5/managed/rmx_web-5.0.4.jar!/com/rapidminer/resources
/i18n/OperatorsDocWeb.xml. (OperatorDocBundle$XMLControl.newBundle())
Miner5\managed\rmx_series-5.0.2.jar'. (OperatorService.registerOperators())
rs/RMUser/.RapidMiner5/managed/rmx_series-5.0.2.jar!/com/rapidminer/resour
ces/i18n/OperatorsDocValueSeries.xml. (OperatorDocBundle$XMLControl.newBundle())
Miner5\managed\rmx_reporting-5.0.2.jar'. (OperatorService.registerOperators())
rs/RMUser/.RapidMiner5/managed/rmx_reporting-5.0.2.jar!/com/rapidminer/res
ources/i18n/OperatorsDocReporting.xml. (OperatorDocBundle$XMLControl.newBundle()
2011-03-02 05:01:28 CONFIG: Number of registered operator classes: 586; number o
f registered operator descriptions: 726; number of replacements: 534 (OperatorSe
rvice.init())
2011-03-02 05:01:28 CONFIG: Loading operator usage statistics. (UsageStatistics.
load())
2011-03-02 05:01:29 CONFIG: Reading parse rules from jar:file:/C:/Program%20File
s/Rapid-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/parserules.xm
2011-03-02 05:01:29 CONFIG: Loading JDBC driver information from 'resource jdbc_
properties.xml'. (DatabaseService.loadJDBCProperties())
2011-03-02 05:01:29 CONFIG: Loaded JDBC driver com.mysql.jdbc.Driver (JDBCProper
ties.registerDrivers())
2011-03-02 05:01:29 CONFIG: Loaded JDBC driver org.postgresql.Driver (JDBCProper
2011-03-02 05:01:29 CONFIG: Loaded JDBC driver net.sourceforge.jtds.jdbc.Driver
(JDBCProperties.registerDrivers())
2011-03-02 05:01:29 CONFIG: Loaded JDBC driver org.hsqldb.jdbcDriver (JDBCProper
2011-03-02 05:01:29 WARNING: Missing database driver class name for 'ODBC Bridge
(e.g. Access)' (JDBCProperties.<init>())
2011-03-02 05:01:29 CONFIG: Loaded JDBC driver com.ingres.jdbc.IngresDriver (JDB
2011-03-02 05:01:29 INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Pro
bably the driver is not installed. (JDBCProperties.registerDrivers())
2011-03-02 05:01:29 INFO: JDBC driver oracle.jdbc.driver.OracleDriver not found.
Probably the driver is not installed. (JDBCProperties.registerDrivers())
2011-03-02 05:01:29 CONFIG: Neither system property 'rapidminer.config.dir' nor
2011-03-02 05:01:29 CONFIG: Loading repositories from C:\Users\RMUser\.Rap
idMiner5\repositories.xml (RepositoryManager.load())
2011-03-02 05:01:29 CONFIG: Adding repository NewLocalRepository (RepositoryMana
ger.addRepository())
2011-03-02 05:01:29 CONFIG: Loading renderers from 'file:/C:/Program%20Files/Rap
id-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/ioobjects.xml'. (R
endererService.init())
2011-03-02 05:01:30 CONFIG: Loading renderers from 'ioobjects.xml'. (RendererSer
vice.init())
2011-03-02 05:01:35 CONFIG: Loading perspectives. (ApplicationPerspectives.loadA
ll())
r'...
Mar 2, 2011 5:01:35 AM com.rapid_i.Launcher ensureRapidMinerHomeSet
Mar 2, 2011 5:01:35 AM com.rapid_i.Launcher main
2011-03-02 05:01:36 CONFIG: Locale not specified explicitly. Set default locale
2011-03-02 05:01:36 INFO: rapidminer.home is 'C:\Program Files\Rapid-I\RapidMine
2011-03-02 05:01:36 CONFIG: Reading configuration resource com/rapidminer/resour
2011-03-02 05:01:36 CONFIG: Neither system property 'rapidminer.config.dir' nor
2011-03-02 05:01:36 CONFIG: Trying rcfile 'C:\Users\RMUser\.RapidMiner5\5_
2011-03-02 05:01:36 CONFIG: Read rcfile 'C:\Users\RMUser\.RapidMiner5\5_1_
2011-03-02 05:01:36 CONFIG: Trying rcfile 'C:\Program Files\Rapid-I\RapidMiner5\
2011-03-02 05:01:36 CONFIG: Property rapidminer.rcfile not specified...skipped (
2011-03-02 05:01:36 CONFIG: Read extension state. (ManagedExtension.readConfigur
ation())
2011-03-02 05:01:36 CONFIG: Scanning plugins in C:\Program Files\Rapid-I\RapidMi
2011-03-02 05:01:36 CONFIG: Loading renderers from 'Text Processing'. (RendererS
ervice.init())
2011-03-02 05:01:36 CONFIG: Reading parse rules from jar:file:/C:/Users/RMUser
2011-03-02 05:01:37 CONFIG: Loading renderers from 'PMML'. (RendererService.init
2011-03-02 05:01:37 CONFIG: Reading parse rules from jar:file:/C:/Users/RMUser
2011-03-02 05:01:37 CONFIG: Loading renderers from 'Weka'. (RendererService.init
2011-03-02 05:01:37 CONFIG: Loading renderers from 'R Extension'. (RendererServi
ce.init())
2011-03-02 05:01:37 CONFIG: Loading renderers from 'PaREn Wizard'. (RendererServ
ice.init())
2011-03-02 05:01:37 CONFIG: Loading renderers from 'Web Mining'. (RendererServic
e.init())
2011-03-02 05:01:37 CONFIG: Loading renderers from 'Series'. (RendererService.in
it())
2011-03-02 05:01:37 CONFIG: Loading renderers from 'Reporting'. (RendererService
.init())
2011-03-02 05:01:37 CONFIG: Loading operators from 'OperatorsCore.xml'. (Operato
2011-03-02 05:01:37 CONFIG: Loading operator documentation from jar:file:/C:/Pro
2011-03-02 05:01:40 WARNING: Password in XML file looks like unencrypted plain t
land
don't know what causes this problems. Did you try to start RapidMiner manually using "java -jar lib\rapidminer.jar" in the command line?
You have to execute the command in the RapidMiner program directory.
Greetings,
Sebastian
