<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.002" expanded="true" name="Process"> <parameter key="parallelize_main_process" value="true"/> <process expanded="true" height="633" width="547"> <operator activated="true" class="generate_data" compatibility="5.1.002" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="target_function" value="polynomial classification"/> </operator> <operator activated="true" class="add_noise" compatibility="5.1.002" expanded="true" height="94" name="Add Noise" width="90" x="180" y="30"> <list key="noise"/> </operator> <operator activated="true" class="x_validation" compatibility="5.0.000" expanded="true" height="112" name="Validation" width="90" x="447" y="30"> <description>A cross-validation evaluating a decision tree model.</description> <process expanded="true" height="654" width="466"> <operator activated="true" breakpoints="after" class="weight_by_relief" compatibility="5.1.002" expanded="true" height="76" name="Weight by Relief" width="90" x="45" y="30"/> <operator activated="true" class="multiply" compatibility="5.1.002" expanded="true" height="94" name="Multiply" width="90" x="45" y="210"/> <operator activated="true" class="scale_by_weights" compatibility="5.1.002" expanded="true" height="76" name="Scale by Weights" width="90" x="179" y="75"/> <operator activated="true" class="decision_tree" compatibility="5.0.000" expanded="true" height="76" name="Decision Tree" width="90" x="313" y="30"/> <connect from_port="training" to_op="Weight by Relief" to_port="example set"/> <connect from_op="Weight by Relief" from_port="weights" to_op="Multiply" to_port="input"/> <connect from_op="Weight by Relief" from_port="example set" to_op="Scale by Weights" to_port="example set"/> <connect from_op="Multiply" from_port="output 1" to_op="Scale by Weights" to_port="weights"/> <connect from_op="Multiply" from_port="output 2" to_port="through 1"/> <connect from_op="Scale by Weights" from_port="example set" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> <portSpacing port="sink_through 2" spacing="0"/> </process> <process expanded="true" height="654" width="476"> <operator activated="true" class="scale_by_weights" compatibility="5.1.002" expanded="true" height="76" name="Scale by Weights (2)" width="90" x="45" y="75"/> <operator activated="true" class="apply_model" compatibility="5.0.000" expanded="true" height="76" name="Apply Model" width="90" x="179" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.0.000" expanded="true" height="76" name="Performance" width="90" x="376" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Scale by Weights (2)" to_port="example set"/> <connect from_port="through 1" to_op="Scale by Weights (2)" to_port="weights"/> <connect from_op="Scale by Weights (2)" from_port="example set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="source_through 2" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Add Noise" to_port="example set input"/> <connect from_op="Add Noise" from_port="example set output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="90"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.002" expanded="true" name="Process"> <process expanded="true" height="550" width="955"> <operator activated="true" class="generate_data" compatibility="5.1.002" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="number_examples" value="1"/> <parameter key="attributes_lower_bound" value="0.0"/> <parameter key="attributes_upper_bound" value="1.0"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.1.002" expanded="true" height="60" name="Extract Macro" width="90" x="45" y="120"> <parameter key="macro" value="att1Weight"/> <parameter key="macro_type" value="statistics"/> <parameter key="statistics" value="max"/> <parameter key="attribute_name" value="att1"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.1.002" expanded="true" height="60" name="Extract Macro (2)" width="90" x="45" y="210"> <parameter key="macro" value="att2Weight"/> <parameter key="macro_type" value="statistics"/> <parameter key="statistics" value="max"/> <parameter key="attribute_name" value="att2"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.1.002" expanded="true" height="60" name="Extract Macro (3)" width="90" x="45" y="300"> <parameter key="macro" value="att3Weight"/> <parameter key="macro_type" value="statistics"/> <parameter key="statistics" value="max"/> <parameter key="attribute_name" value="att3"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.1.002" expanded="true" height="60" name="Extract Macro (4)" width="90" x="45" y="390"> <parameter key="macro" value="att4Weight"/> <parameter key="macro_type" value="statistics"/> <parameter key="statistics" value="max"/> <parameter key="attribute_name" value="att4"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.1.002" expanded="true" height="60" name="Extract Macro (5)" width="90" x="45" y="480"> <parameter key="macro" value="att5Weight"/> <parameter key="macro_type" value="statistics"/> <parameter key="statistics" value="max"/> <parameter key="attribute_name" value="att5"/> </operator> <operator activated="true" class="weight_by_user_specification" compatibility="5.1.002" expanded="true" height="76" name="Weight by User Specification" width="90" x="246" y="165"> <parameter key="normalize_weights" value="false"/> <list key="name_regex_to_weights"> <parameter key="att1.*" value="%{att1Weight}"/> <parameter key="att2.*" value="%{att2Weight}"/> <parameter key="att3.*" value="%{att3Weight}"/> <parameter key="att4.*" value="%{att4Weight}"/> <parameter key="att5.*" value="%{att5Weight}"/> </list> </operator> <connect from_op="Generate Data" from_port="output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Extract Macro (2)" to_port="example set"/> <connect from_op="Extract Macro (2)" from_port="example set" to_op="Extract Macro (3)" to_port="example set"/> <connect from_op="Extract Macro (3)" from_port="example set" to_op="Extract Macro (4)" to_port="example set"/> <connect from_op="Extract Macro (4)" from_port="example set" to_op="Extract Macro (5)" to_port="example set"/> <connect from_op="Extract Macro (5)" from_port="example set" to_op="Weight by User Specification" to_port="example set"/> <connect from_op="Weight by User Specification" from_port="weights" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
