"How using NumericalMatrix in groovy"
User: "sja"
New Altair Community Member
Updated by Jocelyn
I've written a groovy script to calculate a new matix from an exampleSet.
import com.rapidminer.operator.visualization.dependencies.NumericalMatrix;
import Jama.Matrix;
ExampleSet exampleSet = operator.getInput(ExampleSet.class);
double[][] data = new double[exampleSet.size()][exampleSet.getAttributes().size()];
int r = 0;
numberOfColumns = exampleSet.getAttributes().size();
String[] columnNames = new String[numberOfColumns];
operator.logNote("nb col"+numberOfColumns);
for (Example example : exampleSet) {
int c = 0;
for (Attribute attribute : exampleSet.getAttributes()) {
columnNames = attribute.getName();
data = example.getValue(attribute);
c++;
r++;
double[][] cooccMatrixEntries = new double[numberOfColumns][numberOfColumns];
for (int i = 0; i < cooccMatrixEntries.length; i++) {
for (int j = i; j < cooccMatrixEntries.length; j++) {
double cooc = getCooc(data, i, j);
cooccMatrixEntries = cooc;
Matrix mcooc = new Matrix(cooccMatrixEntries);
NumericalMatrix nummat = NumericalMatrix("Cooc matrix",columnNames, mcooc, false);
return nummat;
and I've got the following error :
Process failed: The scripting engine Groovy reported an error in the script: groovy.lang.MissingMethodException: No signature of method: Script1.NumericalMatrix() is applicable for argument types: (java.lang.String, [Ljava.lang.String;, Jama.Matrix, java.lang.Boolean).
I don't understand why because I've included
Thanks for your help.
Steph
1 - 2 of 21
    User: "steffen"
    Hello Steph
    Finally a meaningful precise problem description  ;D
    My attempt to run the script failed because the method getCooc(...) was not available. So here is only a guess regarding your error:
    The word "new" is missing in the third-last line, hence the interpreter "thinks" that NumericalMatrix is the name of a method instead of a constructor.
    hope this was helpful,
    steffen
    User: "sja"
    OP
    thanks for your help,
    It works now and it was a very stupid error.
    Steph.
