I have a question about the "Loop clusters" method. If I have a loop that loops over a number of clutsers, how can I get the output from all the X-validations I have going inside the loop? With this setup I only get the output of the last loop in the output. If there are say 5 clusters, how do I get all the results to the output? Alternatively, how can I save the "Perofrmance vector" classification matrix as simple text (I don't want the whole performance-thing save to a RM object).
Simple example:
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.0.11" expanded="true" name="Process">
<process expanded="true" height="325" width="480">
<operator activated="true" class="retrieve" compatibility="5.0.11" expanded="true" height="60" name="Retrieve (2)" width="90" x="45" y="75">
<parameter key="repository_entry" value="//Samples/data/Golf"/>
<operator activated="true" class="set_role" compatibility="5.0.11" expanded="true" height="76" name="Set Role" width="90" x="179" y="75">
<parameter key="name" value="Outlook"/>
<parameter key="target_role" value="cluster"/>
<operator activated="true" class="loop_clusters" compatibility="5.0.11" expanded="true" height="94" name="Loop Clusters" width="90" x="313" y="75">
<process expanded="true" height="559" width="720">
<operator activated="true" class="x_validation" compatibility="5.0.11" expanded="true" height="112" name="Validation (2)" width="90" x="246" y="30">
<parameter key="number_of_validations" value="3"/>
<parameter key="sampling_type" value="shuffled sampling"/>
<process expanded="true" height="559" width="335">
<operator activated="true" class="k_nn" compatibility="5.0.11" expanded="true" height="76" name="k-NN (3)" width="90" x="122" y="30">
<parameter key="k" value="9"/>
<parameter key="weighted_vote" value="true"/>
<connect from_port="training" to_op="k-NN (3)" to_port="training set"/>
<connect from_op="k-NN (3)" from_port="model" to_port="model"/>
<connect from_op="k-NN (3)" from_port="exampleSet" to_port="through 1"/>
<portSpacing port="source_training" spacing="0"/>
<portSpacing port="sink_through 2" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.0.11" expanded="true" height="76" name="Apply Model (2)" width="90" x="45" y="30">
<operator activated="true" class="find_threshold" compatibility="5.0.11" expanded="true" height="76" name="Find Threshold (3)" width="90" x="179" y="30">
<parameter key="misclassification_costs_second" value="1.4"/>
<operator activated="true" class="apply_threshold" compatibility="5.0.11" expanded="true" height="76" name="Apply Threshold (3)" width="90" x="45" y="210"/>
<operator activated="true" class="performance" compatibility="5.0.11" expanded="true" height="76" name="Performance (4)" width="90" x="179" y="210"/>
<connect from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_op="Find Threshold (3)" to_port="example set"/>
<connect from_op="Find Threshold (3)" from_port="example set" to_op="Apply Threshold (3)" to_port="example set"/>
<connect from_op="Find Threshold (3)" from_port="threshold" to_op="Apply Threshold (3)" to_port="threshold"/>
<connect from_op="Apply Threshold (3)" from_port="example set" to_op="Performance (4)" to_port="labelled data"/>
<connect from_op="Performance (4)" from_port="performance" to_port="averagable 1"/>
<portSpacing port="source_through 2" spacing="0"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_port="cluster subset" to_op="Validation (2)" to_port="training"/>
<connect from_op="Validation (2)" from_port="model" to_port="out 1"/>
<connect from_op="Validation (2)" from_port="averagable 1" to_port="out 2"/>
<portSpacing port="source_cluster subset" spacing="0"/>
<portSpacing port="sink_out 3" spacing="0"/>
</process>
<connect from_op="Retrieve (2)" from_port="output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Loop Clusters" to_port="example set"/>
<connect from_op="Loop Clusters" from_port="out 1" to_port="result 1"/>
<connect from_op="Loop Clusters" from_port="out 2" to_port="result 2"/>
</process>
</process>
