<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.001" expanded="true" name="Process"> <process expanded="true" height="179" width="346"> <operator activated="true" class="retrieve" compatibility="5.1.001" expanded="true" height="60" name="Retrieve" width="90" x="74" y="62"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="split_data" compatibility="5.1.001" expanded="true" height="94" name="Split Data" width="90" x="246" y="75"> <enumeration key="partitions"> <parameter key="ratio" value="0.7"/> <parameter key="ratio" value="0.3"/> </enumeration> <parameter key="use_local_random_seed" value="true"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Split Data" to_port="example set"/> <connect from_op="Split Data" from_port="partition 1" to_port="result 1"/> <connect from_op="Split Data" from_port="partition 2" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
