Hi there,
I am completely new to RapidMiner and quite new to statistics in general. Up to now I only worked a little bit with SPSS.
Now in RapidMiner I wanted to repeat the things I've already done with SPSS, e.g. a Principal Component Analysis.
But I have no idea, which operators and parameters are necessary to create the kind of output I am used to when working with SPSS:
Uploaded with
ImageShack.usThere I've had a number of variables (Exx and Oxx) and set a fixed number (2) of components. The SPSS output is a table showing the factor loadings for all of my original variables.
After then I usually would evaluate the loadings, group the variables according to their factor loadings and drop variables with too low values.
It seems that RapidMiner's PCA operator is doing something similar but I have no clue, which variables the PC's are generated from or how the PCs are computed.
I hope my explanation isn't too confusing. Maybe RapidMiner simply doesn't offer PCA this way.
Is there anybody out there who can help me?
Best regards,
ron
