<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.000" expanded="true" name="Root"> <description><p> A simple and usually fast possibility to perform feature selection is to first calculate attribute weights from the given data set (in this process: Relief) and to apply an AttributeWeightSelection operator afterwards. This operator deselects all features not fulfilling a given weight relation. </p> <p>This is usually referred to as &quot;filter approach&quot; since no other information than the data set is used. If the performance of a specific learner should be taken into account we refer to this as &quot;wrapper approach&quot;. The next sample processes give examples for different wrapper approaches for feature weighting, selection, and construction.</p></description> <process expanded="true" height="604" width="480"> <operator activated="true" class="retrieve" compatibility="5.0.000" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Polynomial"/> </operator> <operator activated="true" class="multiply" compatibility="5.1.001" expanded="true" height="94" name="Multiply" width="90" x="112" y="210"/> <operator activated="true" class="weight_by_relief" compatibility="5.0.000" expanded="true" height="76" name="Relief" width="90" x="179" y="30"/> <operator activated="true" class="scale_by_weights" compatibility="5.1.001" expanded="true" height="76" name="Scale by Weights" width="90" x="380" y="30"/> <connect from_op="Retrieve" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Relief" to_port="example set"/> <connect from_op="Multiply" from_port="output 2" to_port="result 2"/> <connect from_op="Relief" from_port="weights" to_op="Scale by Weights" to_port="weights"/> <connect from_op="Relief" from_port="example set" to_op="Scale by Weights" to_port="example set"/> <connect from_op="Scale by Weights" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.002" expanded="true" name="Process"> <parameter key="parallelize_main_process" value="true"/> <process expanded="true" height="633" width="547"> <operator activated="true" class="generate_data" compatibility="5.1.002" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="target_function" value="polynomial classification"/> </operator> <operator activated="true" class="add_noise" compatibility="5.1.002" expanded="true" height="94" name="Add Noise" width="90" x="180" y="30"> <list key="noise"/> </operator> <operator activated="true" class="x_validation" compatibility="5.0.000" expanded="true" height="112" name="Validation" width="90" x="447" y="30"> <description>A cross-validation evaluating a decision tree model.</description> <process expanded="true" height="654" width="466"> <operator activated="true" breakpoints="after" class="weight_by_relief" compatibility="5.1.002" expanded="true" height="76" name="Weight by Relief" width="90" x="45" y="30"/> <operator activated="true" class="multiply" compatibility="5.1.002" expanded="true" height="94" name="Multiply" width="90" x="45" y="210"/> <operator activated="true" class="scale_by_weights" compatibility="5.1.002" expanded="true" height="76" name="Scale by Weights" width="90" x="179" y="75"/> <operator activated="true" class="decision_tree" compatibility="5.0.000" expanded="true" height="76" name="Decision Tree" width="90" x="313" y="30"/> <connect from_port="training" to_op="Weight by Relief" to_port="example set"/> <connect from_op="Weight by Relief" from_port="weights" to_op="Multiply" to_port="input"/> <connect from_op="Weight by Relief" from_port="example set" to_op="Scale by Weights" to_port="example set"/> <connect from_op="Multiply" from_port="output 1" to_op="Scale by Weights" to_port="weights"/> <connect from_op="Multiply" from_port="output 2" to_port="through 1"/> <connect from_op="Scale by Weights" from_port="example set" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> <portSpacing port="sink_through 2" spacing="0"/> </process> <process expanded="true" height="654" width="476"> <operator activated="true" class="scale_by_weights" compatibility="5.1.002" expanded="true" height="76" name="Scale by Weights (2)" width="90" x="45" y="75"/> <operator activated="true" class="apply_model" compatibility="5.0.000" expanded="true" height="76" name="Apply Model" width="90" x="179" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.0.000" expanded="true" height="76" name="Performance" width="90" x="376" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Scale by Weights (2)" to_port="example set"/> <connect from_port="through 1" to_op="Scale by Weights (2)" to_port="weights"/> <connect from_op="Scale by Weights (2)" from_port="example set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="source_through 2" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Add Noise" to_port="example set input"/> <connect from_op="Add Noise" from_port="example set output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="90"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
