HI
Im trying install RA on Winxp using Postgresql. I can get to step 3 Initial Web-based Conguration following the Installation Instructions pdf.
However, at this step I cannot progress as Postgres is not listed. I have manually setup the tables, and I can see that during the running of run.bat that further tables were created in the postgres database, so RA is connecting to the database.
In the web admin there is also the following:
INFO: Result of SQL dialect autodetection: null.
INFO: Quartz tables must be created.
INFO: com.rapidanalytics.uploaddir not set.
INFO: com.rapidanalytics.plugindir not set.
How can I move beyond this step?
Here is a link to the output from the starup, should that be of assistance:
https://docs.google.com/document/d/1JAtRxbA3eWImY3la4wHfZG4DhPY8vHCRi5hFl1LdlXs/edit?hl=en&authkey=CLiQrbkP
