<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.001" expanded="true" name="Root"> <process expanded="true" height="379" width="705"> <operator activated="true" class="retrieve" compatibility="5.1.001" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="multiply" compatibility="5.1.001" expanded="true" height="112" name="Multiply" width="90" x="180" y="30"/> <operator activated="true" class="set_minus" compatibility="5.1.001" expanded="true" height="76" name="Create EmptySet" width="90" x="315" y="30"/> <operator activated="true" class="remember" compatibility="5.1.001" expanded="true" height="60" name="Remember" width="90" x="450" y="30"> <parameter key="name" value="TEMP"/> <parameter key="io_object" value="ExampleSet"/> </operator> <operator activated="true" class="loop_until" compatibility="5.1.001" expanded="true" height="76" name="Loop Until" width="90" x="313" y="165"> <process expanded="true" height="386" width="681"> <operator activated="true" class="recall" compatibility="5.1.001" expanded="true" height="60" name="Recall" width="90" x="45" y="210"> <parameter key="name" value="TEMP"/> <parameter key="io_object" value="ExampleSet"/> </operator> <operator activated="true" class="set_minus" compatibility="5.1.001" expanded="true" height="76" name="Set Minus" width="90" x="112" y="75"/> <operator activated="true" class="sample" compatibility="5.1.001" expanded="true" height="76" name="Sample" width="90" x="246" y="75"> <parameter key="sample_size" value="1"/> <list key="sample_size_per_class"/> <list key="sample_ratio_per_class"/> <list key="sample_probability_per_class"/> </operator> <operator activated="true" class="remember" compatibility="5.1.001" expanded="true" height="60" name="Remember (2)" width="90" x="380" y="75"> <parameter key="name" value="TEMP"/> <parameter key="io_object" value="ExampleSet"/> </operator> <operator activated="true" class="extract_performance" compatibility="5.1.001" expanded="true" height="76" name="Performance" width="90" x="514" y="75"> <parameter key="performance_type" value="number_of_attributes"/> </operator> <connect from_port="input 1" to_op="Set Minus" to_port="example set input"/> <connect from_op="Recall" from_port="result" to_op="Set Minus" to_port="subtrahend"/> <connect from_op="Set Minus" from_port="example set output" to_op="Sample" to_port="example set input"/> <connect from_op="Sample" from_port="example set output" to_op="Remember (2)" to_port="store"/> <connect from_op="Remember (2)" from_port="stored" to_op="Performance" to_port="example set"/> <connect from_op="Performance" from_port="performance" to_port="performance"/> <connect from_op="Performance" from_port="example set" to_port="example set"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="36"/> <portSpacing port="sink_example set" spacing="18"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Create EmptySet" to_port="example set input"/> <connect from_op="Multiply" from_port="output 2" to_op="Create EmptySet" to_port="subtrahend"/> <connect from_op="Multiply" from_port="output 3" to_op="Loop Until" to_port="input 1"/> <connect from_op="Create EmptySet" from_port="example set output" to_op="Remember" to_port="store"/> <connect from_op="Loop Until" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.001" expanded="true" name="Root"> <process expanded="true" height="379" width="705"> <operator activated="true" class="retrieve" compatibility="5.1.001" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.1.001" expanded="true" height="60" name="Extract Macro" width="90" x="186" y="19"> <parameter key="macro" value="Count"/> </operator> <operator activated="true" class="loop" compatibility="5.1.001" expanded="true" height="76" name="Loop" width="90" x="313" y="30"> <parameter key="iterations" value="%{Count}"/> <process expanded="true" height="357" width="872"> <operator activated="true" class="filter_example_range" compatibility="5.1.001" expanded="true" height="76" name="Filter Example Range" width="90" x="112" y="30"> <parameter key="first_example" value="%{a}"/> <parameter key="last_example" value="%{Count}"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.1.001" expanded="true" height="60" name="Extract Macro (2)" width="90" x="246" y="30"> <parameter key="macro" value="Sub_Count"/> </operator> <operator activated="true" class="provide_macro_as_log_value" compatibility="5.1.001" expanded="true" height="76" name="Provide Macro as Log Value" width="90" x="380" y="30"> <parameter key="macro_name" value="Sub_Count"/> </operator> <operator activated="true" class="log" compatibility="5.1.001" expanded="true" height="76" name="Log" width="90" x="581" y="30"> <list key="log"> <parameter key="Filter" value="operator.Provide Macro as Log Value.value.macro_value"/> </list> </operator> <connect from_port="input 1" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Extract Macro (2)" to_port="example set"/> <connect from_op="Extract Macro (2)" from_port="example set" to_op="Provide Macro as Log Value" to_port="through 1"/> <connect from_op="Provide Macro as Log Value" from_port="through 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Loop" to_port="input 1"/> <connect from_op="Loop" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
