Rapidminer by Script
Jepse
Hi All,
i tried to start a RM-Process by command line using rapidminer-script (./scripts/rapidminer). My Process works perfect within RM. But when i start the process by following command, it doesn't find my stored elements like model or example set.
rapidminer -f /reposi/process.rmp
What am i doing wrong?
Extract of Commandline-Error:
2011-01-26 19:17:19 WARNING: Caught exception in concurrent execution of getTestData (Retrieve): com.rapidminer.operator.UserError: Cannot retrieve repository data from entry '//reposi/05_test_dataset'. Reason: Requested repository ebros does not exist.. (ParallelUnitExecutor$OperatorExecution.run())
com.rapidminer.operator.UserError: Cannot retrieve repository data from entry '//reposi//05_test_dataset'. Reason: Requested repository ebros does not exist..
com.rapidminer.operator.io.RepositorySource.read(RepositorySource.java:106)
com.rapidminer.operator.io.AbstractReader.doWork(AbstractReader.java:123)
com.rapidminer.operator.Operator.execute(Operator.java:771)
com.rapidminer.operator.executor.ParallelUnitExecutor$OperatorExecution.run(ParallelUnitExecutor.java:37)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
java.lang.Thread.run(Thread.java:662)
Caused by:
com.rapidminer.repository.RepositoryException: Requested repository ebros does not exist.
com.rapidminer.repository.RepositoryManager.getRepository(RepositoryManager.java:170)
com.rapidminer.repository.RepositoryLocation.getRepository(RepositoryLocation.java:153)
com.rapidminer.repository.RepositoryLocation.locateEntry(RepositoryLocation.java:173)
com.rapidminer.operator.io.RepositorySource.getRepositoryEntry(RepositorySource.java:91)
com.rapidminer.operator.io.RepositorySource.read(RepositorySource.java:104)
2011-01-26 19:17:19 WARNING: Caught exception in concurrent execution of getModell (Retrieve): com.rapidminer.operator.UserError: Cannot retrieve repository data from entry '//reposi/01_model_no_boosting'. Reason: Requested repository reposi does not exist.. (ParallelUnitExecutor$OperatorExecution.run())
com.rapidminer.operator.UserError: Cannot retrieve repository data from entry '//reposi/01_model_no_boosting'. Reason: Requested repository ebros does not exist..
Caused by:
Cheers, Philippe
SebastianLoh
Hi Phillipe,
if you use the -f (for file) parameter, the repository location in your retrieve operator cannot be resolved.
The -f option is deprecated. Try
rapidminer //myRepositoryNameInRapidMiner/myProcess.rmp
This should work.
Ciao Sebastian
Jepse
Ok, i tried that. No i receive a new Error.
riable 'RAPIDMINER_CONFIG_DIR' not set. Ignored. (ParameterService.getGlobalConfigDir())
2011-01-27 11:49:49 CONFIG: Initializing Data Repository (RapidMiner.splashMessage())
2011-01-27 11:49:49 CONFIG: Loading repositories from /home/jpw/.RapidMiner5/repositories.xml (RepositoryManager.load())
2011-01-27 11:49:49 CONFIG: Adding repository Repository (RepositoryManager.addRepository())
2011-01-27 11:49:49 CONFIG: Initializing XML Serialization (RapidMiner.splashMessage())
2011-01-27 11:49:49 CONFIG: Defining XML Serialization Alias Pairs (RapidMiner.splashMessage())
2011-01-27 11:49:49 CONFIG: Initializing Renderers (RapidMiner.splashMessage())
2011-01-27 11:49:49 CONFIG: Loading renderers from 'file:/home/jpw/rapidminer/lib/rapidminer.jar!/com/rapidminer/resources/ioobjects.xml'. (RendererService.init())
2011-01-27 11:49:49 CONFIG: Loading renderers from 'ioobjects.xml'. (RendererService.init())
2011-01-27 11:49:49 SEVERE: Cannot read process setup '//reposi/02_apply_model_on_unclassified': Cannot locate entry '//ebros/sentiment_prediction/02_apply_model_on_unclassified': com.rapidminer.repository.RepositoryException: Requested repository ebros does not exist. (RapidMinerCommandLine.run())
It sais that the repository is not available? Could this error caused the missing RAPIDMINER_CONF_DIR?
Jepse
Solved:
My Repository was stored in my root account but not my specific user. So all i had to do is changing the user to root and rerun the command.
1. sudo su -
2. ./rapidminer //reposi/process
