rapid miner dies before starting
cidiel
i ran the recent updates for rapid miner and it currently doesn't even load up. it gets to the extension loading part of the startup and then just stops.. if i run it from the cmd then it just loops but never gets started... any ideas?
cidiel
2011-01-24 14:03:24 WARNING: Missing database driver class name for 'ODBC Bridge
(e.g. Access)' (JDBCProperties.<init>())
2011-01-24 14:03:24 CONFIG: Loaded JDBC driver net.sourceforge.jtds.jdbc.Driver
(JDBCProperties.registerDrivers())
2011-01-24 14:03:24 CONFIG: Loaded JDBC driver com.ingres.jdbc.IngresDriver (JDB
2011-01-24 14:03:24 INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Pro
bably the driver is not installed. (JDBCProperties.registerDrivers())
2011-01-24 14:03:24 INFO: JDBC driver oracle.jdbc.driver.OracleDriver not found.
Probably the driver is not installed. (JDBCProperties.registerDrivers())
2011-01-24 14:03:24 CONFIG: Neither system property 'rapidminer.config.dir' nor
environment variable 'RAPIDMINER_CONFIG_DIR' not set. Ignored. (ParameterService
.getGlobalConfigDir())
2011-01-24 14:03:24 CONFIG: Loading repositories from C:\Documents and Settings\
bleidich\.RapidMiner5\repositories.xml (RepositoryManager.load())
2011-01-24 14:03:24 CONFIG: Adding repository NewLocalRepository (RepositoryMana
ger.addRepository())
2011-01-24 14:03:24 CONFIG: Loading renderers from 'file:/C:/Program%20Files/Rap
id-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/ioobjects.xml'. (R
endererService.init())
2011-01-24 14:03:24 CONFIG: Loading renderers from 'ioobjects.xml'. (RendererSer
vice.init())
2011-01-24 14:03:27 CONFIG: Loading perspectives. (ApplicationPerspectives.loadA
ll())
2011-01-24 14:03:27 WARNING: Missing I18N key: gui.action.workspace_ge.label (I1
8N.getMessage())
####### This is about where it bombs out and starts over from what i can tell
cidiel
well, i'm talking to myself but in the fwiw column it's def the rapid-miner R installation that is causing the issue.. i deleted that and have had no problems since.. really would like to get this working but the R-extension for whatever reason just does not want to play nice. I'm near certain i have all the variables etc.. set correctly. chalk it up to another R-extension issue.
land
did you update all extensions? Unfortunately there was a bug, causing to crash RapidMiner 5.1.001 with some of the old extensions. We fixed the bug, but I don't know which extension caused the trouble. I think it was the Text Processing Extension. Did you have it installed?
Greetings,
Sebastian
