it tried to install the RapidAnalytics system on the following platform but it fails.
- Oracle Solaris 11 Express 2010.11
- GlassFish Server Open Source Edition 3.0.1 (build 22)
- MySQL 5.1.37
I created a database with the name rapidanalytics. Then I tried to install a new application in the GlassFish Server by importing the File RapidAnalytics.ear but it fails with error. In the mysql database the following tables has been created:
| Tables_in_rapidanalytics |
| SEQUENCE |
| ra_ent_accesslog |
| ra_ent_bytebuffer |
| ra_ent_dbconnectionentry |
| ra_ent_entry |
| ra_ent_exportedprocess |
| ra_ent_group |
| ra_ent_parametermapping |
| ra_ent_permission |
| ra_ent_processexecparam |
| ra_ent_processlogrecord |
| ra_ent_processlogrecords |
| ra_ent_properties |
| ra_ent_property |
| ra_ent_scheduledprocess |
| ra_ent_trigger |
| ra_ent_user |
| ra_ent_version |
| ra_rel_entry_permission |
| ra_rel_expproc_param |
| ra_rel_group_user |
| ra_rel_logrecords |
| ra_rel_user_group |
Hope you can help. I added the error log at the bottom. It`s not the full error log because it would exceed the maximum size of a post. If you need the whole log please let me know.
Thanks
Thomas
[#|2011-01-24T15:03:24.648+0100|WARNING|glassfish3.0.1|org.apache.catalina.connector.Request|_ThreadID=29;_ThreadName=Thread-1;|PWC4011: Unable to set request character encoding to UTF-8 from context , because request parameters have already been read, or ServletRequest.getReader() has already been called|#]
[#|2011-01-24T15:03:35.299+0100|INFO|glassfish3.0.1|javax.enterprise.webservices.org.glassfish.webservices|_ThreadID=29;_ThreadName=Thread-1;|WS00018: Webservice Endpoint deployed
ProcessService listening at address at http://localhost:8080/RAWS/ProcessService|#]
[#|2011-01-24T15:03:35.300+0100|INFO|glassfish3.0.1|javax.enterprise.webservices.org.glassfish.webservices|_ThreadID=29;_ThreadName=Thread-1;|WS00018: Webservice Endpoint deployed
RepositoryService listening at address at http://localhost:8080/RAWS/RepositoryService|#]
[#|2011-01-24T15:03:38.372+0100|INFO|glassfish3.0.1|javax.enterprise.system.core.classloading.com.sun.enterprise.loader|_ThreadID=29;_ThreadName=Thread-1;|de.rapidanalytics.entity.ProcessLogRecord actually got transformed|#]
[#|2011-01-24T15:03:39.715+0100|INFO|glassfish3.0.1|org.hibernate.validator.engine.resolver.DefaultTraversableResolver|_ThreadID=29;_ThreadName=Thread-1;|Instantiated an instance of org.hibernate.validator.engine.resolver.JPATraversableResolver.|#]
[#|2011-01-24T15:03:39.760+0100|INFO|glassfish3.0.1|org.eclipse.persistence.session.file:/opt/glassfish-3.0.1/glassfish/domains/domain1/applications/RapidAnalytics/lib/RapidRepositoryEntity.jar_RapidRepositoryEntity|_ThreadID=29;_ThreadName=Thread-1;|EclipseLink, version: Eclipse Persistence Services - 2.0.1.v20100213-r6600|#]
[#|2011-01-24T15:03:40.347+0100|SEVERE|glassfish3.0.1|javax.enterprise.system.std.com.sun.enterprise.v3.services.impl|_ThreadID=29;_ThreadName=Thread-1;|line 1:140 no viable alternative at character '!'|#]
[#|2011-01-24T15:03:40.371+0100|SEVERE|glassfish3.0.1|javax.enterprise.system.std.com.sun.enterprise.v3.services.impl|_ThreadID=29;_ThreadName=Thread-1;|line 1:107 no viable alternative at character '!'|#]
[#|2011-01-24T15:03:40.375+0100|INFO|glassfish3.0.1|org.eclipse.persistence.session.file:/opt/glassfish-3.0.1/glassfish/domains/domain1/applications/RapidAnalytics/lib/RapidRepositoryEntity.jar_RapidRepositoryEntity|_ThreadID=29;_ThreadName=Thread-1;|file:/opt/glassfish-3.0.1/glassfish/domains/domain1/applications/RapidAnalytics/lib/RapidRepositoryEntity.jar_RapidRepositoryEntity login successful|#]
[#|2011-01-24T15:03:40.643+0100|WARNING|glassfish3.0.1|javax.enterprise.system.tools.deployment.org.glassfish.persistence.common|_ThreadID=29;_ThreadName=Thread-1;|Got SQLException executing statement "": java.sql.SQLException: Can not issue empty query.|#]
[#|2011-01-24T15:03:41.236+0100|INFO|glassfish3.0.1|javax.enterprise.system.container.ejb.com.sun.ejb.containers|_ThreadID=29;_ThreadName=Thread-1;|Portable JNDI names for EJB AccessLogEJBImpl : [java:global/RapidAnalytics/RapidRepositoryEJB/AccessLogEJBImpl, java:global/RapidAnalytics/RapidRepositoryEJB/AccessLogEJBImpl!de.rapidanalytics.ejb.AccessLogEJB]|#]
[#|2011-01-24T15:03:42.515+0100|INFO|glassfish3.0.1|javax.enterprise.system.container.ejb.com.sun.ejb.containers|_ThreadID=29;_ThreadName=Thread-1;|EJB5109:EJB Timer Service started successfully for datasource [jdbc/__TimerPool]|#]
[#|2011-01-24T15:03:42.521+0100|INFO|glassfish3.0.1|javax.enterprise.system.container.ejb.com.sun.ejb.containers|_ThreadID=29;_ThreadName=Thread-1;|==> Restoring Timers ... |#]
[#|2011-01-24T15:03:42.521+0100|INFO|glassfish3.0.1|javax.enterprise.system.container.ejb.com.sun.ejb.containers|_ThreadID=29;_ThreadName=Thread-1;|<== ... Timers Restored.|#]
[#|2011-01-24T15:03:42.661+0100|INFO|glassfish3.0.1|javax.enterprise.system.container.web.com.sun.enterprise.web|_ThreadID=29;_ThreadName=Thread-1;|Loading application ejb-timer-service-app at /ejb-timer-service-app|#]
[#|2011-01-24T15:03:42.661+0100|INFO|glassfish3.0.1|javax.enterprise.system.container.web.com.sun.enterprise.web|_ThreadID=29;_ThreadName=http-thread-pool-4848-(1);|Loading application ejb-timer-service-app at /ejb-timer-service-app|#]
[#|2011-01-24T15:03:42.669+0100|INFO|glassfish3.0.1|javax.enterprise.system.container.ejb.com.sun.ejb.containers|_ThreadID=29;_ThreadName=Thread-1;|Portable JNDI names for EJB SchedulerEJBImpl : [java:global/RapidAnalytics/RapidRepositoryEJB/SchedulerEJBImpl!de.rapidanalytics.ejb.SchedulerEJB, java:global/RapidAnalytics/RapidRepositoryEJB/SchedulerEJBImpl]|#]
[#|2011-01-24T15:03:46.823+0100|INFO|glassfish3.0.1|javax.enterprise.system.core.transaction.com.sun.jts.CosTransactions|_ThreadID=29;_ThreadName=Thread-1;|JTS5014: Recoverable JTS instance, serverId = [3700]|#]
[#|2011-01-24T15:03:48.808+0100|INFO|glassfish3.0.1|javax.enterprise.system.container.ejb.com.sun.ejb.containers|_ThreadID=29;_ThreadName=Thread-1;|Portable JNDI names for EJB ProcessJobEJBImpl : [java:global/RapidAnalytics/RapidRepositoryEJB/ProcessJobEJBImpl, java:global/RapidAnalytics/RapidRepositoryEJB/ProcessJobEJBImpl!de.rapidanalytics.ejb.ProcessJobEJB]|#]
[#|2011-01-24T15:03:48.824+0100|INFO|glassfish3.0.1|javax.enterprise.system.container.ejb.com.sun.ejb.containers|_ThreadID=29;_ThreadName=Thread-1;|Glassfish-specific (Non-portable) JNDI names for EJB ProcessJobEJBImpl : [ejb/ProcessJobEJB, ejb/ProcessJobEJB#de.rapidanalytics.ejb.ProcessJobEJB]|#]
[#|2011-01-24T15:03:49.031+0100|INFO|glassfish3.0.1|javax.enterprise.system.container.ejb.com.sun.ejb.containers|_ThreadID=29;_ThreadName=Thread-1;|Portable JNDI names for EJB TriggerEJBImpl : [java:global/RapidAnalytics/RapidRepositoryEJB/TriggerEJBImpl, java:global/RapidAnalytics/RapidRepositoryEJB/TriggerEJBImpl!de.rapidanalytics.ejb.TriggerEJB]|#]
[#|2011-01-24T15:03:49.043+0100|INFO|glassfish3.0.1|javax.enterprise.system.container.ejb.com.sun.ejb.containers|_ThreadID=29;_ThreadName=Thread-1;|Glassfish-specific (Non-portable) JNDI names for EJB TriggerEJBImpl : [ejb/TriggerEJB, ejb/TriggerEJB#de.rapidanalytics.ejb.TriggerEJB]|#]
[#|2011-01-24T15:03:49.080+0100|INFO|glassfish3.0.1|javax.enterprise.system.container.ejb.com.sun.ejb.containers|_ThreadID=29;_ThreadName=Thread-1;|Portable JNDI names for EJB ExportedProcessEJBImpl : [java:global/RapidAnalytics/RapidRepositoryEJB/ExportedProcessEJBImpl!de.rapidanalytics.ejb.ExportedProcessEJB, java:global/RapidAnalytics/RapidRepositoryEJB/ExportedProcessEJBImpl]|#]
[#|2011-01-24T15:03:49.240+0100|INFO|glassfish3.0.1|org.hibernate.validator.engine.resolver.DefaultTraversableResolver|_ThreadID=29;_ThreadName=Thread-1;|Instantiated an instance of org.hibernate.validator.engine.resolver.JPATraversableResolver.|#]
[#|2011-01-24T15:03:49.257+0100|INFO|glassfish3.0.1|org.eclipse.persistence.session.file:/opt/glassfish-3.0.1/glassfish/domains/domain1/applications/ejb-timer-service-app/WEB-INF/classes/___EJB__Timer__App|_ThreadID=29;_ThreadName=Thread-1;|EclipseLink, version: Eclipse Persistence Services - 2.0.1.v20100213-r6600|#]
[#|2011-01-24T15:03:51.384+0100|INFO|glassfish3.0.1|org.eclipse.persistence.session.file:/opt/glassfish-3.0.1/glassfish/domains/domain1/applications/ejb-timer-service-app/WEB-INF/classes/___EJB__Timer__App|_ThreadID=29;_ThreadName=Thread-1;|file:/opt/glassfish-3.0.1/glassfish/domains/domain1/applications/ejb-timer-service-app/WEB-INF/classes/___EJB__Timer__App login successful|#]
[#|2011-01-24T15:03:52.128+0100|INFO|glassfish3.0.1|javax.enterprise.resource.webcontainer.jsf.config|_ThreadID=29;_ThreadName=Thread-1;|Mojarra 2.0.2 (FCS b10) für Kontext '/RAWS' wird initialisiert.|#]
[#|2011-01-24T15:03:52.693+0100|WARNING|glassfish3.0.1|javax.enterprise.system.core.security|_ThreadID=29;_ThreadName=Thread-1;|No Principals mapped to Role [rmuser].|#]
[#|2011-01-24T15:03:52.741+0100|INFO|glassfish3.0.1|javax.enterprise.system.container.web.com.sun.enterprise.web|_ThreadID=29;_ThreadName=Thread-1;|Loading application RapidAnalytics#RapidRepositoryWebService.war at RAWS|#]
[#|2011-01-24T15:03:52.741+0100|INFO|glassfish3.0.1|javax.enterprise.system.container.web.com.sun.enterprise.web|_ThreadID=29;_ThreadName=http-thread-pool-4848-(1);|Loading application RapidAnalytics#RapidRepositoryWebService.war at RAWS|#]
[#|2011-01-24T15:03:54.569+0100|INFO|glassfish3.0.1|javax.enterprise.resource.webcontainer.jsf.config|_ThreadID=29;_ThreadName=Thread-1;|Mojarra 2.0.2 (FCS b10) für Kontext '/RA' wird initialisiert.|#]
[#|2011-01-24T15:03:55.465+0100|INFO|glassfish3.0.1|javax.enterprise.resource.webcontainer.jsf.config|_ThreadID=29;_ThreadName=Thread-1;|Unsanitized stacktrace from failed start...
com.sun.faces.config.ConfigurationException: Factory 'javax.faces.render.RenderKitFactory' was not configured properly.
at com.sun.faces.config.processor.FactoryConfigProcessor.verifyFactoriesExist(FactoryConfigProcessor.java:305)
at com.sun.faces.config.processor.FactoryConfigProcessor.process(FactoryConfigProcessor.java:220)
at com.sun.faces.config.ConfigManager.initialize(ConfigManager.java:335)
at com.sun.faces.config.ConfigureListener.contextInitialized(ConfigureListener.java:223)
at org.apache.catalina.core.StandardContext.contextListenerStart(StandardContext.java:4664)
at com.sun.enterprise.web.WebModule.contextListenerStart(WebModule.java:535)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:5266)
at com.sun.enterprise.web.WebModule.start(WebModule.java:499)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:928)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:912)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:694)
at com.sun.enterprise.web.WebContainer.loadWebModule(WebContainer.java:1947)
at com.sun.enterprise.web.WebContainer.loadWebModule(WebContainer.java:1619)
at com.sun.enterprise.web.WebApplication.start(WebApplication.java:90)
at org.glassfish.internal.data.EngineRef.start(EngineRef.java:126)
at org.glassfish.internal.data.ModuleInfo.start(ModuleInfo.java:241)
at org.glassfish.internal.data.ApplicationInfo.start(ApplicationInfo.java:236)
at com.sun.enterprise.v3.server.ApplicationLifecycle.deploy(ApplicationLifecycle.java:339)
at com.sun.enterprise.v3.server.ApplicationLifecycle.deploy(ApplicationLifecycle.java:183)
at org.glassfish.deployment.admin.DeployCommand.execute(DeployCommand.java:272)
at com.sun.enterprise.v3.admin.CommandRunnerImpl$1.execute(CommandRunnerImpl.java:305)
at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(CommandRunnerImpl.java:320)
at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(CommandRunnerImpl.java:1176)
at com.sun.enterprise.v3.admin.CommandRunnerImpl.access$900(CommandRunnerImpl.java:83)
at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionContext.execute(CommandRunnerImpl.java:1235)
at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionContext.execute(CommandRunnerImpl.java:1224)
at org.glassfish.admingui.common.util.LocalDeploymentFacility$LocalDFCommandRunner.run(LocalDeploymentFacility.java:138)
at org.glassfish.deployment.client.AbstractDeploymentFacility.deploy(AbstractDeploymentFacility.java:350)
at org.glassfish.admingui.common.util.DeployUtil.invokeDeploymentFacility(DeployUtil.java:89)
at org.glassfish.admingui.common.util.DeployUtil.deploy(DeployUtil.java:66)
at org.glassfish.admingui.common.handlers.DeploymentHandler.deploy(DeploymentHandler.java:186)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at com.sun.jsftemplating.layout.descriptors.handler.Handler.invoke(Handler.java:442)
at com.sun.jsftemplating.layout.descriptors.LayoutElementBase.dispatchHandlers(LayoutElementBase.java:420)
at com.sun.jsftemplating.layout.descriptors.LayoutElementBase.dispatchHandlers(LayoutElementBase.java:394)
at com.sun.jsftemplating.layout.event.CommandActionListener.invokeCommandHandlers(CommandActionListener.java:150)
at com.sun.jsftemplating.layout.event.CommandActionListener.processAction(CommandActionListener.java:98)
at javax.faces.event.ActionEvent.processListener(ActionEvent.java:88)
at javax.faces.component.UIComponentBase.broadcast(UIComponentBase.java:772)
at javax.faces.component.UICommand.broadcast(UICommand.java:300)
at com.sun.webui.jsf.component.WebuiCommand.broadcast(WebuiCommand.java:166)
at javax.faces.component.UIViewRoot.broadcastEvents(UIViewRoot.java:775)
at javax.faces.component.UIViewRoot.processApplication(UIViewRoot.java:1267)
at com.sun.faces.lifecycle.InvokeApplicationPhase.execute(InvokeApplicationPhase.java:82)
at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:101)
at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:118)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:312)
at org.apache.catalina.core.StandardWrapper.service(StandardWrapper.java:1523)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:343)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:215)
at com.sun.webui.jsf.util.UploadFilter.doFilter(UploadFilter.java:223)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:256)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:277)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:188)
at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:641)
at com.sun.enterprise.web.WebPipeline.invoke(WebPipeline.java:97)
at com.sun.enterprise.web.PESessionLockingStandardPipeline.invoke(PESessionLockingStandardPipeline.java:85)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:185)
at org.apache.catalina.connector.CoyoteAdapter.doService(CoyoteAdapter.java:325)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:226)
at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:239)
at com.sun.grizzly.http.ProcessorTask.invokeAdapter(ProcessorTask.java:791)
at com.sun.grizzly.http.ProcessorTask.doProcess(ProcessorTask.java:693)
at com.sun.grizzly.http.ProcessorTask.process(ProcessorTask.java:954)
at com.sun.grizzly.http.DefaultProtocolFilter.execute(DefaultProtocolFilter.java:170)
at com.sun.grizzly.DefaultProtocolChain.executeProtocolFilter(DefaultProtocolChain.java:135)
at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:102)
at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:88)
at com.sun.grizzly.http.HttpProtocolChain.execute(HttpProtocolChain.java:76)
at com.sun.grizzly.ProtocolChainContextTask.doCall(ProtocolChainContextTask.java:53)
at com.sun.grizzly.SelectionKeyContextTask.call(SelectionKeyContextTask.java:57)
at com.sun.grizzly.ContextTask.run(ContextTask.java:69)
at com.sun.grizzly.util.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:330)
at com.sun.grizzly.util.AbstractThreadPool$Worker.run(AbstractThreadPool.java:309)
at java.lang.Thread.run(Thread.java:619)
Caused by: javax.faces.FacesException: org.ajax4jsf.renderkit.ChameleonRenderKitFactory
at javax.faces.FactoryFinder.getImplGivenPreviousImpl(FactoryFinder.java:593)
at javax.faces.FactoryFinder.getImplementationInstance(FactoryFinder.java:472)
at javax.faces.FactoryFinder.access$400(FactoryFinder.java:139)
at javax.faces.FactoryFinder$FactoryManager.getFactory(FactoryFinder.java:796)
at javax.faces.FactoryFinder.getFactory(FactoryFinder.java:306)
at com.sun.faces.config.processor.FactoryConfigProcessor.verifyFactoriesExist(FactoryConfigProcessor.java:303)
... 78 more
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
at javax.faces.FactoryFinder.getImplGivenPreviousImpl(FactoryFinder.java:586)
... 83 more
Caused by: java.lang.NoClassDefFoundError: org/apache/commons/collections/ArrayStack
at org.apache.commons.digester.Digester.<init>(Digester.java:153)
at org.ajax4jsf.resource.ResourceBuilderImpl.registerConfig(ResourceBuilderImpl.java:171)
at org.ajax4jsf.resource.ResourceBuilderImpl.registerResources(ResourceBuilderImpl.java:155)
at org.ajax4jsf.resource.ResourceBuilderImpl.init(ResourceBuilderImpl.java:226)
at org.ajax4jsf.renderkit.ChameleonRenderKitFactory.<init>(ChameleonRenderKitFactory.java:62)
... 88 more
Caused by: java.lang.ClassNotFoundException: org.apache.commons.collections.ArrayStack
at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at org.glassfish.web.loader.WebappClassLoader.findClass(WebappClassLoader.java:959)
at org.glassfish.web.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1430)
... 93 more
