<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.001" expanded="true" name="Process"> <process expanded="true" height="449" width="681"> <operator activated="true" class="generate_data" compatibility="5.1.001" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="target_function" value="simple polynomial classification"/> </operator> <operator activated="true" class="multiply" compatibility="5.1.001" expanded="true" height="94" name="Multiply" width="90" x="179" y="30"/> <operator activated="true" class="random_forest" compatibility="5.1.001" expanded="true" height="76" name="Random Forest" width="90" x="313" y="30"/> <operator activated="true" breakpoints="after" class="weight_by_user_specification" compatibility="5.1.001" expanded="true" height="76" name="Weight by User Specification" width="90" x="313" y="165"> <parameter key="normalize_weights" value="false"/> <list key="name_regex_to_weights"/> <parameter key="default_weight" value="0.0"/> </operator> <operator activated="true" breakpoints="after" class="weights_to_data" compatibility="5.1.001" expanded="true" height="60" name="Weights to Data (2)" width="90" x="447" y="165"/> <operator activated="true" class="weight_by_forest" compatibility="5.1.001" expanded="true" height="76" name="Weight by Tree Importance" width="90" x="447" y="30"/> <operator activated="true" class="weights_to_data" compatibility="5.1.001" expanded="true" height="60" name="Weights to Data" width="90" x="574" y="33"/> <operator activated="true" class="append" compatibility="5.1.001" expanded="true" height="94" name="Append" width="90" x="447" y="300"/> <operator activated="true" class="aggregate" compatibility="5.1.001" expanded="true" height="76" name="Aggregate" width="90" x="581" y="300"> <list key="aggregation_attributes"> <parameter key="Weight" value="sum"/> </list> <parameter key="group_by_attributes" value="Attribute"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Random Forest" to_port="training set"/> <connect from_op="Multiply" from_port="output 2" to_op="Weight by User Specification" to_port="example set"/> <connect from_op="Random Forest" from_port="model" to_op="Weight by Tree Importance" to_port="random forest"/> <connect from_op="Weight by User Specification" from_port="weights" to_op="Weights to Data (2)" to_port="attribute weights"/> <connect from_op="Weights to Data (2)" from_port="example set" to_op="Append" to_port="example set 2"/> <connect from_op="Weight by Tree Importance" from_port="weights" to_op="Weights to Data" to_port="attribute weights"/> <connect from_op="Weights to Data" from_port="example set" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
