package rapidminer_5x;import com.rapidminer.repository.RepositoryLocation;import com.rapidminer.tools.OperatorService ;import com.rapidminer.ProcessContext;import com.rapidminer.RapidMiner;import com.rapidminer.RapidMiner.ExecutionMode;import com.rapidminer.Process;import com.rapidminer.operator.*;import com.rapidminer.operator.io.ModelWriter;import com.rapidminer.operator.io.RepositorySource;import com.rapidminer.operator.learner.functions.neuralnet.NeuralNetLearner;import com.rapidminer.operator.ports.*;import com.rapidminer.operator.validation.XValidation;public class Test { /** * @param argv */ public static void main (String [] argv) { try { //Set the execution mode in which to run RM RapidMiner.setExecutionMode(ExecutionMode.COMMAND_LINE); // Initialize Rapidminer RapidMiner.init(); } catch (Exception e) { e.printStackTrace(); } // Create a process Process process = new Process(); try { /*Create a location entry for the repository that * is to be used as input */ RepositoryLocation location = new RepositoryLocation ("//Samples/data/Iris"); String loc = process.makeRelativeRepositoryLocation(location); // create input operator Operator retrieve = OperatorService.createOperator(RepositorySource.class); /*Set the parameter of the operator to the location of *the repository entry */ retrieve.setParameter("repository_entry", loc); //Create the neural network operator NeuralNetLearner neuralNet = OperatorService.createOperator(NeuralNetLearner.class); //Create the model writer Operator modelWriter = OperatorService.createOperator(ModelWriter.class); //Create the XValidation operator chain XValidation xvalidation = OperatorService.createOperator(XValidation.class); xvalidation.setExpanded(true); //Set the parameters for model writer modelWriter.setParameter("model_file", "D:/Bhavya/RapidMiner/test2.mod"); modelWriter.setParameter("output_type","XML"); //Create the output port of the retrieve operator OutputPort retrieveOutput = retrieve .getOutputPorts().getPortByName("output"); //Create the input port of XValidation InputPort xvalidationInput = xvalidation.getInputPorts() .getPortByName("training"); //Create the input port of Neural Net InputPort neuralNetInput = neuralNet.getInputPorts() .getPortByName("training set"); //Create the output port of Neural Net OutputPort neuralNetOutput = neuralNet.getOutputPorts() .getPortByName("model"); //Create the input port of Model Writer InputPort modelWriterInput = modelWriter.getInputPorts() .getPortByName("input"); //Create the output port of Model Writer OutputPort modelWriterOutput = modelWriter.getOutputPorts() .getPortByName("through"); xvalidation.shouldAutoConnect(neuralNetInput); xvalidation.getSubprocess(0).addOperator(neuralNet); xvalidation.getSubprocess(0).addOperator(modelWriter); //ExecutionUnit exec = //xvalidation.getSubprocess(0).autoWireSingle(neuralNet, null, true, true); //Connect the output port of Retrieve to the input port //of xvalidation retrieveOutput.connectTo(xvalidationInput); //retrieveOutput.connectTo(neuralNetInput); neuralNetInput = neuralNet.getExampleSetInputPort(); // add operator to process process.getRootOperator().getSubprocess(0) .addOperator(retrieve); process.getRootOperator().getSubprocess(0) .addOperator(xvalidation); //Connect the output of neural net to the input of model writer neuralNetOutput.connectTo(modelWriterInput); //Connect the input of xvalidation to the input of neural net// IOObject data = xvalidationInput.getAnyDataOrNull();// /* //IOOb //xvalidation.execute(); IOObject input = xvalidationInput.getData(); neuralNetInput.receive(input); neuralNet.shouldAutoConnect(xvalidationInput); * * */ //print process setup System.out.println(process.getRootOperator().createProcessTree(0)); // perform process process.run(); xvalidationInput.receive(retrieveOutput.getData()); IOObject data = xvalidationInput.getData(); neuralNetInput.receive(data); } catch(Exception e) { e.printStackTrace(); } }}
package rapidminer_5x;import com.rapidminer.Process;import com.rapidminer.RapidMiner;import com.rapidminer.RapidMiner.ExecutionMode;import com.rapidminer.operator.ExecutionUnit;import com.rapidminer.operator.ModelApplier;import com.rapidminer.operator.Operator;import com.rapidminer.operator.io.ModelWriter;import com.rapidminer.operator.io.RepositorySource;import com.rapidminer.operator.learner.functions.neuralnet.ImprovedNeuralNetLearner;import com.rapidminer.operator.performance.PerformanceEvaluator;import com.rapidminer.operator.validation.XValidation;import com.rapidminer.repository.RepositoryLocation;import com.rapidminer.tools.OperatorService;public class Test { private static Operator createRetrievalOperator(Process parentProcess) throws Exception { RepositoryLocation location = new RepositoryLocation( "//Samples/data/Iris"); String loc = parentProcess.makeRelativeRepositoryLocation(location); // create input operator Operator retrieve = OperatorService .createOperator(RepositorySource.class); /* * Set the parameter of the operator to the location of the repository * entry */ retrieve.setParameter("repository_entry", loc); return retrieve; } private static Operator createModelWriter() throws Exception { // Create the model writer Operator modelWriter = OperatorService .createOperator(ModelWriter.class); // Set the parameters for model writer modelWriter.setParameter("model_file", "c:/nn_run_%{a}.mode"); modelWriter.setParameter("output_type", "XML"); return modelWriter; } /** * Connect the output-port <code>fromPortName</code> from Operator * <code>from</code> with the input-port <code>toPortName</code> of Operator * <code>to</code>. */ private static void connect(Operator from, String fromPortName, Operator to, String toPortName) { from.getOutputPorts().getPortByName(fromPortName).connectTo( to.getInputPorts().getPortByName(toPortName)); } /** * Connect the output-port <code>fromPortName</code> from Subprocess * <code>from</code> with the input-port <code>toPortName</code> of Operator * <code>to</code>. */ private static void connect(ExecutionUnit from, String fromPortName, Operator to, String toPortName) { from.getInnerSources().getPortByName(fromPortName).connectTo( to.getInputPorts().getPortByName(toPortName)); } /** * Connect the output-port <code>fromPortName</code> from Operator * <code>from</code> with the input-port <code>toPortName</code> of * Subprocess <code>to</code>. */ private static void connect(Operator from, String fromPortName, ExecutionUnit to, String toPortName) { from.getOutputPorts().getPortByName(fromPortName).connectTo( to.getInnerSinks().getPortByName(toPortName)); } public static void main(String[] argv) throws Exception { // init rapidminer RapidMiner.setExecutionMode(ExecutionMode.COMMAND_LINE); RapidMiner.init(); // Create a process final Process process = new Process(); // all operators from "left to right" final Operator retrieve = createRetrievalOperator(process); final XValidation xvalidation = OperatorService .createOperator(XValidation.class); xvalidation.setParameter(XValidation.PARAMETER_NUMBER_OF_VALIDATIONS, Integer.valueOf(2).toString()); final ImprovedNeuralNetLearner neuralNet = OperatorService .createOperator(ImprovedNeuralNetLearner.class); final Operator modelWriter = createModelWriter(); final Operator modelApplier = OperatorService .createOperator(ModelApplier.class); final Operator performance = OperatorService .createOperator(PerformanceEvaluator.class); // add operators to the main process and connect them process.getRootOperator().getSubprocess(0).addOperator(retrieve); process.getRootOperator().getSubprocess(0).addOperator(xvalidation); connect(retrieve, "output", xvalidation, "training"); // xvalidation // training part of xvalidation xvalidation.getSubprocess(0).addOperator(neuralNet); xvalidation.getSubprocess(0).addOperator(modelWriter); // create connection within training process: from left to right ... connect(xvalidation.getSubprocess(0), "training", neuralNet, "training set"); connect(neuralNet, "model", modelWriter, "input"); connect(modelWriter, "through", xvalidation.getSubprocess(0), "model"); // testing part of xvalidation xvalidation.getSubprocess(1).addOperator(modelApplier); xvalidation.getSubprocess(1).addOperator(performance); // create connection within testing process: from left to right ... connect(xvalidation.getSubprocess(1), "model", modelApplier, "model"); connect(xvalidation.getSubprocess(1), "test set", modelApplier, "unlabelled data"); connect(modelApplier, "labelled data", performance, "labelled data"); connect(performance, "performance", xvalidation.getSubprocess(1), "averagable 1"); // print process setup System.out.println(process.getRootOperator().createProcessTree(0)); // perform process process.run(); }}
