So that's basically a pre-processing step based on a genetic algorithm for combining operators.
/* * RapidMiner * * Copyright (C) 2001-2010 by Rapid-I and the contributors * * Complete list of developers available at our web site: * * http://rapid-i.com * * This program is free software: you can redistribute it and/or modify * it under the terms of the GNU Affero General Public License as published by * the Free Software Foundation, either version 3 of the License, or * (at your option) any later version. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU Affero General Public License for more details. * * You should have received a copy of the GNU Affero General Public License * along with this program. If not, see http://www.gnu.org/licenses/. */package com.rapidminer.operator.features.construction;import java.util.ArrayList;import java.util.Iterator;import java.util.LinkedList;import java.util.List;import com.rapidminer.example.Attribute;import com.rapidminer.example.ExampleSet;import com.rapidminer.generator.AbsoluteValueGenerator;import com.rapidminer.generator.BasicArithmeticOperationGenerator;import com.rapidminer.generator.ExponentialFunctionGenerator;import com.rapidminer.generator.FeatureGenerator;import com.rapidminer.generator.FloorCeilGenerator;import com.rapidminer.generator.MinMaxGenerator;import com.rapidminer.generator.PowerGenerator;import com.rapidminer.generator.ReciprocalValueGenerator;import com.rapidminer.generator.SquareRootGenerator;import com.rapidminer.generator.TrigonometricFunctionGenerator;import com.rapidminer.operator.OperatorDescription;import com.rapidminer.operator.OperatorException;import com.rapidminer.operator.ports.metadata.AttributeMetaData;import com.rapidminer.operator.ports.metadata.ExampleSetMetaData;import com.rapidminer.operator.ports.metadata.MetaData;import com.rapidminer.parameter.ParameterType;import com.rapidminer.parameter.ParameterTypeBoolean;import com.rapidminer.parameter.UndefinedParameterError;import com.rapidminer.tools.Ontology;import com.rapidminer.tools.math.MathFunctions;/** * This operator applies a set of functions on all features of the input example set. Applicable functions include +, -, * *, /, norm, sin, cos, tan, atan, exp, log, min, max, floor, ceil, round, sqrt, abs, and pow. Features with two * arguments will be applied on all pairs. Non commutative functions will also be applied on all permutations. * * @see com.rapidminer.generator.FeatureGenerator * @author Ingo Mierswa */public class CompleteFeatureGenerationOperator extends AbstractFeatureConstruction { /** * The parameter name for "If set to true, all the original attributes are kept, otherwise they are removed * from the example set." */ public static final String PARAMETER_KEEP_ALL = "keep_all"; /** The parameter name for "Generate sums." */ public static final String PARAMETER_USE_PLUS = "use_plus"; /** The parameter name for "Generate differences." */ public static final String PARAMETER_USE_DIFF = "use_diff"; /** The parameter name for "Generate products." */ public static final String PARAMETER_USE_MULT = "use_mult"; /** The parameter name for "Generate quotients." */ public static final String PARAMETER_USE_DIV = "use_div"; /** The parameter name for "Generate reciprocal values." */ public static final String PARAMETER_USE_RECIPROCALS = "use_reciprocals"; /** The parameter name for "Generate square root values." */ public static final String PARAMETER_USE_SQUARE_ROOTS = "use_square_roots"; /** The parameter name for "Generate the power of one attribute and another." */ public static final String PARAMETER_USE_POWER_FUNCTIONS = "use_power_functions"; /** The parameter name for "Generate sinus." */ public static final String PARAMETER_USE_SIN = "use_sin"; /** The parameter name for "Generate cosinus." */ public static final String PARAMETER_USE_COS = "use_cos"; /** The parameter name for "Generate tangens." */ public static final String PARAMETER_USE_TAN = "use_tan"; /** The parameter name for "Generate arc tangens." */ public static final String PARAMETER_USE_ATAN = "use_atan"; /** The parameter name for "Generate exponential functions." */ public static final String PARAMETER_USE_EXP = "use_exp"; /** The parameter name for "Generate logarithmic functions." */ public static final String PARAMETER_USE_LOG = "use_log"; /** The parameter name for "Generate absolute values." */ public static final String PARAMETER_USE_ABSOLUTE_VALUES = "use_absolute_values"; /** The parameter name for "Generate minimum values." */ public static final String PARAMETER_USE_MIN = "use_min"; /** The parameter name for "Generate maximum values." */ public static final String PARAMETER_USE_MAX = "use_max"; /** The parameter name for "Generate ceil values." */ public static final String PARAMETER_USE_CEIL = "use_ceil"; /** The parameter name for "Generate floor values." */ public static final String PARAMETER_USE_FLOOR = "use_floor"; /** The parameter name for "Generate rounded values." */ public static final String PARAMETER_USE_ROUNDED = "use_rounded"; public CompleteFeatureGenerationOperator(OperatorDescription description) { super(description); }@Override protected MetaData modifyMetaData(ExampleSetMetaData metaData) throws UndefinedParameterError { // counting numerical attributes int numberOfNumerical = 0; for (AttributeMetaData amd : metaData.getAllAttributes()) { if (amd.isNumerical() && !amd.isSpecial()) numberOfNumerical++; } // clear regular if needed if (!getParameterAsBoolean(PARAMETER_KEEP_ALL)) metaData.clearRegular(); // new ones int numberOfAdditionalAttributes = 0; int commutativeNonSelfapplicable = MathFunctions.factorial(numberOfNumerical - 1); int commutativeSelfapplicable = MathFunctions.factorial(numberOfNumerical); int nonCommuatativeSelfApplicable = numberOfNumerical * numberOfNumerical; int nonCommuatativeNonSelfApplicable = numberOfNumerical * numberOfNumerical; if (getParameterAsBoolean(PARAMETER_USE_PLUS)) numberOfAdditionalAttributes += commutativeNonSelfapplicable; if (getParameterAsBoolean(PARAMETER_USE_DIFF)) numberOfAdditionalAttributes += nonCommuatativeNonSelfApplicable; if (getParameterAsBoolean(PARAMETER_USE_MULT)) numberOfAdditionalAttributes += commutativeSelfapplicable; if (getParameterAsBoolean(PARAMETER_USE_DIV)) numberOfAdditionalAttributes += nonCommuatativeNonSelfApplicable; if (getParameterAsBoolean(PARAMETER_USE_RECIPROCALS)) numberOfAdditionalAttributes += numberOfNumerical; if (getParameterAsBoolean(PARAMETER_USE_SQUARE_ROOTS)) { numberOfAdditionalAttributes += numberOfNumerical; } if (getParameterAsBoolean(PARAMETER_USE_POWER_FUNCTIONS)) { numberOfAdditionalAttributes += nonCommuatativeSelfApplicable; } if (getParameterAsBoolean(PARAMETER_USE_SIN)) numberOfAdditionalAttributes += numberOfNumerical; if (getParameterAsBoolean(PARAMETER_USE_COS)) numberOfAdditionalAttributes += numberOfNumerical; if (getParameterAsBoolean(PARAMETER_USE_TAN)) numberOfAdditionalAttributes += numberOfNumerical; if (getParameterAsBoolean(PARAMETER_USE_ATAN)) numberOfAdditionalAttributes += numberOfNumerical; if (getParameterAsBoolean(PARAMETER_USE_EXP)) numberOfAdditionalAttributes += numberOfNumerical; if (getParameterAsBoolean(PARAMETER_USE_LOG)) numberOfAdditionalAttributes += numberOfNumerical; if (getParameterAsBoolean(PARAMETER_USE_ABSOLUTE_VALUES)) numberOfAdditionalAttributes += numberOfNumerical; if (getParameterAsBoolean(PARAMETER_USE_MIN)) numberOfAdditionalAttributes += commutativeNonSelfapplicable; if (getParameterAsBoolean(PARAMETER_USE_MAX)) numberOfAdditionalAttributes += commutativeNonSelfapplicable; if (getParameterAsBoolean(PARAMETER_USE_CEIL)) numberOfAdditionalAttributes += numberOfNumerical; if (getParameterAsBoolean(PARAMETER_USE_FLOOR)) numberOfAdditionalAttributes += numberOfNumerical; if (getParameterAsBoolean(PARAMETER_USE_ROUNDED)) numberOfAdditionalAttributes += numberOfNumerical; for (int i = 0; i < numberOfAdditionalAttributes; i++) { if (i == 0) metaData.addAttribute(new AttributeMetaData("gensym", Ontology.REAL)); else metaData.addAttribute(new AttributeMetaData("gensym" + i, Ontology.REAL)); } return metaData; }@Override public ExampleSet apply(ExampleSet exampleSet) throws OperatorException { // set selection mode to restrictive mode FeatureGenerator.setSelectionMode(FeatureGenerator.SELECTION_MODE_RESTRICTIVE); List<FeatureGenerator> generators = getGenerators(); List<FeatureGenerator> generatorList = new LinkedList<FeatureGenerator>(); Iterator<FeatureGenerator> i = generators.iterator(); while (i.hasNext()) { FeatureGenerator generator = i.next(); List<Attribute[]> inputAttributes = generator.getInputCandidates(exampleSet, new String[0]); Iterator<Attribute[]> a = inputAttributes.iterator(); while (a.hasNext()) { Attribute[] args = a.next(); FeatureGenerator newGenerator = generator.newInstance(); newGenerator.setArguments(args); generatorList.add(newGenerator); } } // generate all new attributes if (!getParameterAsBoolean(PARAMETER_KEEP_ALL)) { exampleSet.getAttributes().clearRegular(); } List<Attribute> newAttributes = FeatureGenerator.generateAll(exampleSet.getExampleTable(), generatorList); for (Attribute newAttribute : newAttributes) exampleSet.getAttributes().addRegular(newAttribute); return exampleSet; } private List<FeatureGenerator> getGenerators() { List<FeatureGenerator> generators = new ArrayList<FeatureGenerator>(); if (getParameterAsBoolean(PARAMETER_USE_PLUS)) generators.add(new BasicArithmeticOperationGenerator(BasicArithmeticOperationGenerator.SUM)); if (getParameterAsBoolean(PARAMETER_USE_DIFF)) generators.add(new BasicArithmeticOperationGenerator(BasicArithmeticOperationGenerator.DIFFERENCE)); if (getParameterAsBoolean(PARAMETER_USE_MULT)) generators.add(new BasicArithmeticOperationGenerator(BasicArithmeticOperationGenerator.PRODUCT)); if (getParameterAsBoolean(PARAMETER_USE_DIV)) generators.add(new BasicArithmeticOperationGenerator(BasicArithmeticOperationGenerator.QUOTIENT)); if (getParameterAsBoolean(PARAMETER_USE_RECIPROCALS)) generators.add(new ReciprocalValueGenerator()); if (getParameterAsBoolean(PARAMETER_USE_SQUARE_ROOTS)) { generators.add(new SquareRootGenerator()); } if (getParameterAsBoolean(PARAMETER_USE_POWER_FUNCTIONS)) { generators.add(new PowerGenerator()); } if (getParameterAsBoolean(PARAMETER_USE_SIN)) generators.add(new TrigonometricFunctionGenerator(TrigonometricFunctionGenerator.SINUS)); if (getParameterAsBoolean(PARAMETER_USE_COS)) generators.add(new TrigonometricFunctionGenerator(TrigonometricFunctionGenerator.COSINUS)); if (getParameterAsBoolean(PARAMETER_USE_TAN)) generators.add(new TrigonometricFunctionGenerator(TrigonometricFunctionGenerator.TANGENS)); if (getParameterAsBoolean(PARAMETER_USE_ATAN)) generators.add(new TrigonometricFunctionGenerator(TrigonometricFunctionGenerator.ARC_TANGENS)); if (getParameterAsBoolean(PARAMETER_USE_EXP)) generators.add(new ExponentialFunctionGenerator(ExponentialFunctionGenerator.EXP)); if (getParameterAsBoolean(PARAMETER_USE_LOG)) generators.add(new ExponentialFunctionGenerator(ExponentialFunctionGenerator.LOG)); if (getParameterAsBoolean(PARAMETER_USE_ABSOLUTE_VALUES)) generators.add(new AbsoluteValueGenerator()); if (getParameterAsBoolean(PARAMETER_USE_MIN)) generators.add(new MinMaxGenerator(MinMaxGenerator.MIN)); if (getParameterAsBoolean(PARAMETER_USE_MAX)) generators.add(new MinMaxGenerator(MinMaxGenerator.MAX)); if (getParameterAsBoolean(PARAMETER_USE_CEIL)) generators.add(new FloorCeilGenerator(FloorCeilGenerator.CEIL)); if (getParameterAsBoolean(PARAMETER_USE_FLOOR)) generators.add(new FloorCeilGenerator(FloorCeilGenerator.FLOOR)); if (getParameterAsBoolean(PARAMETER_USE_ROUNDED)) generators.add(new FloorCeilGenerator(FloorCeilGenerator.ROUND)); return generators; }@Override public List<ParameterType> getParameterTypes() { List<ParameterType> types = super.getParameterTypes(); types.add(new ParameterTypeBoolean(PARAMETER_KEEP_ALL, "If set to true, all the original attributes are kept, otherwise they are removed from the example set.", true, false)); types.add(new ParameterTypeBoolean(PARAMETER_USE_PLUS, "Generate sums.", false, false)); types.add(new ParameterTypeBoolean(PARAMETER_USE_DIFF, "Generate differences.", false, false)); types.add(new ParameterTypeBoolean(PARAMETER_USE_MULT, "Generate products.", false, false)); types.add(new ParameterTypeBoolean(PARAMETER_USE_DIV, "Generate quotients.", false, false)); types.add(new ParameterTypeBoolean(PARAMETER_USE_RECIPROCALS, "Generate reciprocal values.", false, false)); types.add(new ParameterTypeBoolean(PARAMETER_USE_SQUARE_ROOTS, "Generate square root values.", false, false)); types.add(new ParameterTypeBoolean(PARAMETER_USE_POWER_FUNCTIONS, "Generate the power of one attribute and another.", false, false)); types.add(new ParameterTypeBoolean(PARAMETER_USE_SIN, "Generate sinus.", false, false)); types.add(new ParameterTypeBoolean(PARAMETER_USE_COS, "Generate cosinus.", false, false)); types.add(new ParameterTypeBoolean(PARAMETER_USE_TAN, "Generate tangens.", false, false)); types.add(new ParameterTypeBoolean(PARAMETER_USE_ATAN, "Generate arc tangens.", false, false)); types.add(new ParameterTypeBoolean(PARAMETER_USE_EXP, "Generate exponential functions.", false, false)); types.add(new ParameterTypeBoolean(PARAMETER_USE_LOG, "Generate logarithmic functions.", false, false)); types.add(new ParameterTypeBoolean(PARAMETER_USE_ABSOLUTE_VALUES, "Generate absolute values.", false, false)); types.add(new ParameterTypeBoolean(PARAMETER_USE_MIN, "Generate minimum values.", false, false)); types.add(new ParameterTypeBoolean(PARAMETER_USE_MAX, "Generate maximum values.", false, false)); types.add(new ParameterTypeBoolean(PARAMETER_USE_CEIL, "Generate ceil values.", false, false)); types.add(new ParameterTypeBoolean(PARAMETER_USE_FLOOR, "Generate floor values.", false, false)); types.add(new ParameterTypeBoolean(PARAMETER_USE_ROUNDED, "Generate rounded values.", false, false)); return types; }}
