Simon Fischer wrote:Hi,the reason for this is the following:Open http://yourhost:port/RAWS/RepositoryService?wsdland scroll down. You will see the hostname is listed in the WSDL. This must be a hostname that your client understands, Otherwise you'll confuse it. The solution you posted is the way to go.Best,Simon
