Hexmesh of fillets
hiranwale_bharat
hiranwale_bharat Altair Community Member
Hello Everyone,
It seems easy but I am bit confused about meshing for 3d fillets as highlighted in the attached figure. If I want to do Hexmesh how can I do it along with this fillets? (I don't want to 'defeature' them)
Regards
Bharat Hiranwale
<?xml version="1.0" encoding="UTF-8"?>post-38425-0-91118000-1439989245_thumb.j
  • Altair Forum User
    Altair Forum User
    edited August 2015
    Have a look at this thread : http://goo.gl/08ssDx
  • hiranwale_bharat
    edited August 2015
    Hello Q.NGUYEN-DAI,
    thank you for the help,but my model has more than 100 fillets. Is there any shortcut for this process or it is to be performed manually every time?
    Bharat
  • Altair Forum User
    Altair Forum User
    edited August 2015
    Hello Q.NGUYEN-DAI,
    Bharat
    More than 100 fillets with hexa mesh? Good luck to you image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    No way to do that automatically.
    Why you need hexa mesh for this case?
  • hiranwale_bharat
    edited August 2015
    image/emoticons/default_sad.png' alt=':(' srcset='/emoticons/sad@2x.png 2x' width='20' height='20'>
    My Problem requirement is in that fashion . I have to check results using higher order tetra and hex elements.
    thanks for the tip.
    Bharat
  • Altair Forum User
    Altair Forum User
    edited August 2015
    That's no sense for an academic work with more than 100 fillets with hex-meshing.
  • Altair Forum User
    Altair Forum User
    edited August 2015
    Hi All,
    If the fillet size and shape are identical, copy and positioning the elements may reduce some work load.
