<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.001" expanded="true" name="Process"> <process expanded="true" height="476" width="882"> <operator activated="true" class="generate_sales_data" compatibility="5.1.001" expanded="true" height="60" name="Generate Sales Data" width="90" x="45" y="75"> <parameter key="number_examples" value="1000"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.1.001" expanded="true" height="76" name="Generate Attributes" width="90" x="112" y="165"> <list key="function_descriptions"> <parameter key="total_price" value="amount*single_price"/> </list> </operator> <operator activated="true" class="set_role" compatibility="5.1.001" expanded="true" height="76" name="Set Role" width="90" x="112" y="255"> <parameter key="name" value="total_price"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.001" expanded="true" height="76" name="Select Attributes" width="90" x="112" y="345"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="product_id|amount|single_price|total_price"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="split_data" compatibility="5.1.001" expanded="true" height="94" name="Split Data" width="90" x="246" y="345"> <enumeration key="partitions"> <parameter key="ratio" value="0.3"/> <parameter key="ratio" value="0.7"/> </enumeration> </operator> <operator activated="true" class="neural_net" compatibility="5.1.001" expanded="true" height="76" name="Neural Net" width="90" x="380" y="210"> <list key="hidden_layers"/> </operator> <operator activated="true" class="apply_model" compatibility="5.1.001" expanded="true" height="76" name="Apply Model (2)" width="90" x="514" y="345"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_regression" compatibility="5.1.001" expanded="true" height="76" name="Performance" width="90" x="648" y="210"> <parameter key="squared_error" value="true"/> <parameter key="correlation" value="true"/> <parameter key="squared_correlation" value="true"/> </operator> <connect from_op="Generate Sales Data" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Split Data" to_port="example set"/> <connect from_op="Split Data" from_port="partition 1" to_op="Neural Net" to_port="training set"/> <connect from_op="Split Data" from_port="partition 2" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Neural Net" from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Apply Model (2)" from_port="model" to_port="result 3"/> <connect from_op="Performance" from_port="performance" to_port="result 1"/> <connect from_op="Performance" from_port="example set" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="270"/> <portSpacing port="sink_result 2" spacing="54"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
