Hello Everyone,
I am simulating rubber parts in compression. In which I am getting Hourglassed elements.
Is it possible in optistruct to overcome this problem or I will have to use Radioss.
Thanks and regards,
Bharat
Hi Bharat,
What type of elements are you using?
You can use PSHELLX/PSOLIDX extensions in Property cards to introduce integration points.
Hello Prakash,
I am using Hex and tet elements.(Solid mostly).
Which parameters are to be defined in PSHELLX / PSOLIDX properties?
Bharat,
Check Isolid in PSOLIDX.
Thanks Prakash,
