I'm trying to use the X-validation (Parallel) operator but I'm getting errors even for very simple processes. I've run the program in 3 different machines (2-core & 4-core) with the same result. I get a "Process Failed. Send bug report?" dialog.
Am I forgetting something obvious and embarrasing?
I don't want submit a bug if I'm the one making a silly mistake.
Thanks for any help,
jlo
Code below:
<process version="5.1.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.001" expanded="true" name="Process">
<process expanded="true" height="197" width="413">
<operator activated="true" class="generate_direct_mailing_data" compatibility="5.1.001" expanded="true" height="60" name="Generate Direct Mailing Data" width="90" x="112" y="63"/>
<operator activated="true" class="parallel:x_validation_parallel" compatibility="5.0.001" expanded="true" height="112" name="Validation" width="90" x="313" y="75">
<process expanded="true">
<operator activated="true" class="decision_tree" compatibility="5.0.000" expanded="true" height="76" name="Decision Tree" width="90" x="45" y="30"/>
<connect from_port="training" to_op="Decision Tree" to_port="training set"/>
<connect from_op="Decision Tree" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.0.000" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
<operator activated="true" class="performance" compatibility="5.0.000" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_op="Generate Direct Mailing Data" from_port="output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="model" to_port="result 1"/>
<connect from_op="Validation" from_port="training" to_port="result 2"/>
</process>
</process>
