<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.000" expanded="true" name="Process"> <process expanded="true" height="190" width="413"> <operator activated="true" class="read_csv" compatibility="5.1.000" expanded="true" height="60" name="Read CSV" width="90" x="45" y="30"> <parameter key="csv_file" value="E:\cerveza.csv"/> <parameter key="column_separators" value=","/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="id.true.integer.id"/> <parameter key="1" value="cerveza.true.integer.label"/> <parameter key="2" value="mujer.true.integer.attribute"/> <parameter key="3" value="educ1.true.integer.attribute"/> <parameter key="4" value="educ2.true.integer.attribute"/> <parameter key="5" value="educ3.true.integer.attribute"/> <parameter key="6" value="ingreso.true.integer.attribute"/> <parameter key="7" value="edad.true.integer.attribute"/> </list> </operator> <operator activated="true" class="read_weights" compatibility="5.1.000" expanded="true" height="60" name="Read Weights" width="90" x="112" y="120"> <parameter key="attribute_weights_file" value="E:\linreg.wgt"/> </operator> <operator activated="true" class="select_by_weights" compatibility="5.1.000" expanded="true" height="94" name="Select by Weights" width="90" x="313" y="75"/> <connect from_op="Read CSV" from_port="output" to_op="Select by Weights" to_port="example set input"/> <connect from_op="Read Weights" from_port="output" to_op="Select by Weights" to_port="weights"/> <connect from_op="Select by Weights" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
