<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.11" expanded="true" name="Process"> <process expanded="true" height="251" width="748"> <operator activated="true" class="read_csv" compatibility="5.0.11" expanded="true" height="60" name="Read CSV" width="90" x="46" y="58"> <parameter key="file_name" value="C:\Documents and Settings\Administrator.KNOWLEDG-P6715Y\My Documents\RM5\a.csv"/> <parameter key="column_separators" value=","/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="nominal_to_binominal" compatibility="5.0.11" expanded="true" height="94" name="Nominal to Binominal" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Product"/> <parameter key="use_underscore_in_name" value="true"/> </operator> <operator activated="true" class="nominal_to_numerical" compatibility="5.0.11" expanded="true" height="94" name="Nominal to Numerical" width="90" x="313" y="30"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="Pr.*"/> </operator> <operator activated="true" class="aggregate" compatibility="5.0.11" expanded="true" height="76" name="Aggregate" width="90" x="447" y="30"> <list key="aggregation_attributes"> <parameter key="Product_Product 1" value="sum"/> <parameter key="Product_Product 2" value="sum"/> <parameter key="Product_Product 3" value="sum"/> </list> <parameter key="group_by_attributes" value="Client|Date"/> </operator> <operator activated="true" class="rename_by_replacing" compatibility="5.0.11" expanded="true" height="76" name="Rename by Replacing" width="90" x="581" y="30"> <parameter key="replace_what" value="sum\(Product_|\)"/> </operator> <connect from_op="Read CSV" from_port="output" to_op="Nominal to Binominal" to_port="example set input"/> <connect from_op="Nominal to Binominal" from_port="example set output" to_op="Nominal to Numerical" to_port="example set input"/> <connect from_op="Nominal to Numerical" from_port="example set output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Rename by Replacing" to_port="example set input"/> <connect from_op="Rename by Replacing" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.11" expanded="true" name="Process"> <process expanded="true" height="251" width="815"> <operator activated="true" class="read_csv" compatibility="5.0.11" expanded="true" height="60" name="Read CSV" width="90" x="46" y="58"> <parameter key="file_name" value="C:\Documents and Settings\Administrator.KNOWLEDG-P6715Y\My Documents\RM5\a.csv"/> <parameter key="column_separators" value=","/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="nominal_to_binominal" compatibility="5.0.11" expanded="true" height="94" name="Nominal to Binominal" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Product"/> <parameter key="use_underscore_in_name" value="true"/> </operator> <operator activated="true" class="nominal_to_numerical" compatibility="5.0.11" expanded="true" height="94" name="Nominal to Numerical" width="90" x="313" y="30"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="Pr.*"/> </operator> <operator activated="true" class="aggregate" compatibility="5.0.11" expanded="true" height="76" name="Aggregate" width="90" x="447" y="30"> <list key="aggregation_attributes"> <parameter key="Product_Product 1" value="sum"/> <parameter key="Product_Product 2" value="sum"/> <parameter key="Product_Product 3" value="sum"/> </list> <parameter key="group_by_attributes" value="Client|Date"/> </operator> <operator activated="true" class="rename_by_replacing" compatibility="5.0.11" expanded="true" height="76" name="Rename by Replacing" width="90" x="581" y="30"> <parameter key="replace_what" value="sum\(Product_|\)"/> </operator> <operator activated="true" class="discretize_by_user_specification" compatibility="5.0.11" expanded="true" height="94" name="Discretize" width="90" x="701" y="34"> <list key="classes"> <parameter key="0" value="0.0"/> <parameter key="1" value="Infinity"/> </list> </operator> <connect from_op="Read CSV" from_port="output" to_op="Nominal to Binominal" to_port="example set input"/> <connect from_op="Nominal to Binominal" from_port="example set output" to_op="Nominal to Numerical" to_port="example set input"/> <connect from_op="Nominal to Numerical" from_port="example set output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Rename by Replacing" to_port="example set input"/> <connect from_op="Rename by Replacing" from_port="example set output" to_op="Discretize" to_port="example set input"/> <connect from_op="Discretize" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
