"R 2.12"
B_Miner
OK, I know this has been asked many times (because the R interface is a great addition, but for those of us that dont really understand JAVA and environment variables (windows), the install is painful).
I had R 2.11and RM worked great. Then I updated to R 2.12 and all hell broke loose! :-\
I *thought* I followed the instruction when RM loaded but I get either errors about dependent libraries not being found or incompatible architecture.
Can anyone explain what needs to be set up?
I have environment variables: classpath, path, JAVA_HOME and R_HOME. What needs to be in each?
i am using 64 bit windows, R and RM.
The R.dll is under ..bin\x64
The library folder is up a few folders (where all the package libraries are at for R). I have rjava (jri.dll) downloaded and think I pointed RM to this file under 64 bit.
Anyone know how to fix?
Many thanks! Brian
R
dragoljub
In RapidMiner go to tools-->preferences-->R tab and set the path to the new location of 64bit R dll. I believe R combined their 32 and 64bit installers. I guess since RM is pretty much designed for 64bit their next update will check the 64bit folder too.
-Gagi
B_Miner
Gagi,
Thanks for the reply -I made that change (the preference tab was pointing to the jri.dll prior) but the result was the same. Something else must be screwed up.
B_Miner
Finally got it working
gusr
Hi B_Miner
How did you sort it out? What was it you had to change in the end to get it to work?
All the best,
gusr
B_Miner
I am using 64 bit Windows 7.
In the environment variables
JAVA_HOME I have C:\Program Files\Java\jre6
R_HOME I have C:\Program Files\R\R-2.12.0
Path I have C:\Program Files\R\R-2.12.0\library
and finally in Rapid Miner under preferences and R and have C:\Program Files\R\R-2.12.0\library\rJava\jri\x64\jri.dll
land
we are going to make the installation procedure more simpler by bundling R directly, but we have still some legal issues as well as architectural problems, because the bundling would not be platform independent...
Greetings,
Sebastian
