"Copy series operator does not deliver series to inner operators"
Hello all,
I cannot get the "Copy Series Operator" to behave. In the attached process I am expecting to be able to extract something from the value series but whatever I do I get an error suggesting that there is no data being delivered to the inner operator within the copy series operator.
What am I doing wrong?
Andrew
regards
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.0.11" expanded="true" name="Process">
<process expanded="true" height="611" width="927">
<operator activated="true" class="generate_data" compatibility="5.0.11" expanded="true" height="60" name="Generate Data" width="90" x="45" y="75">
<parameter key="target_function" value="simple sinus"/>
<parameter key="number_examples" value="1000"/>
<parameter key="number_of_attributes" value="1"/>
<operator activated="true" class="sort" compatibility="5.0.11" expanded="true" height="76" name="Sort" width="90" x="45" y="165">
<parameter key="attribute_name" value="att1"/>
<operator activated="true" class="select_attributes" compatibility="5.0.11" expanded="true" height="76" name="Select Attributes" width="90" x="45" y="255">
<parameter key="attributes" value="att2|att1"/>
<operator activated="true" class="transpose" compatibility="5.0.11" expanded="true" height="76" name="Transpose" width="90" x="45" y="345"/>
<operator activated="true" class="series:process_series" compatibility="5.0.2" expanded="true" height="76" name="Process Series" width="90" x="313" y="255">
<parameter key="start_attribute" value="att_1"/>
<parameter key="end_attribute" value="att_1000"/>
<process expanded="true" height="458" width="945">
<operator activated="true" class="series:copy_series" compatibility="5.0.2" expanded="true" height="60" name="Copy Series (2)" width="90" x="313" y="30">
<parameter key="keep_only_last" value="false"/>
<process expanded="true" height="637" width="945">
<operator activated="true" class="series:extract_average" compatibility="5.0.2" expanded="true" height="60" name="Extract Average (3)" width="90" x="427" y="30"/>
<connect from_port="series 1" to_op="Extract Average (3)" to_port="series"/>
<connect from_op="Extract Average (3)" from_port="series" to_port="series 1"/>
<portSpacing port="source_series 1" spacing="0"/>
<portSpacing port="source_series 2" spacing="0"/>
<portSpacing port="sink_series 1" spacing="0"/>
<portSpacing port="sink_series 2" spacing="0"/>
</process>
<connect from_port="series" to_op="Copy Series (2)" to_port="series"/>
<connect from_op="Copy Series (2)" from_port="series" to_port="series"/>
<portSpacing port="source_series" spacing="0"/>
<portSpacing port="sink_series" spacing="0"/>
</process>
<connect from_op="Generate Data" from_port="output" to_op="Sort" to_port="example set input"/>
<connect from_op="Sort" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Transpose" to_port="example set input"/>
<connect from_op="Transpose" from_port="example set output" to_op="Process Series" to_port="example set"/>
<connect from_op="Process Series" from_port="example set" to_port="result 1"/>
</process>
</process>
Andrew
