Hello Everyone
I have been trying to use pretension manager in which I gave the value of pretension on the contact surface as 20 (just for trial)
I am using MPA system for units. This was followed by a static subcase.
During results I found that deflection due to preload is much higher( of the order of 10e5). I reduced the load value to 2 still the deflection was of the order 10e3.
I have checked my model and everything is fine (load,constraints etc).
Can anyone tell me what is the solution for this problem?
Bharat
