<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process"> <process expanded="true" height="296" width="413"> <operator activated="true" class="retrieve" compatibility="5.0.8" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="multiply" compatibility="5.0.8" expanded="true" height="94" name="Multiply" width="90" x="179" y="30"/> <operator activated="true" class="generate_attributes" compatibility="5.0.8" expanded="true" height="76" name="Generate Attributes" width="90" x="313" y="120"> <list key="function_descriptions"> <parameter key="Sum" value="a1+a2"/> </list> </operator> <operator activated="true" class="r:execute_script_r" compatibility="5.0.1" expanded="true" height="76" name="Execute Script (R)" width="90" x="313" y="30"> <parameter key="script" value="x <- as.data.frame(c(data, data[1] + data[2])) colnames(x)[6] = "Sum""/> <enumeration key="inputs"> <parameter key="name_of_variable" value="data"/> </enumeration> <list key="results"> <parameter key="x" value="Data Table"/> </list> </operator> <connect from_op="Retrieve" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Execute Script (R)" to_port="input 1"/> <connect from_op="Multiply" from_port="output 2" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 2"/> <connect from_op="Execute Script (R)" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="72"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
