"Help with Word List Operator"
I am trying to add the WordList Operator to this Word Vector code I am working on. I cannot enable it properly. I would appreciate any suggestions on implementing the WordList Operator. I wanted to add it to the end so I can get a list of each word with a count.
Thanks,
Ron McEwan
Thanks,
Ron McEwan
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.0.11" expanded="true" name="Process">
<process expanded="true" height="431" width="413">
<operator activated="true" class="web:get_webpage" compatibility="5.0.4" expanded="true" height="60" name="Get Page" width="90" x="55" y="46">
<parameter key="url" value="http://seekingalpha.com/news/market_currents?source=refreshed"/>
<list key="query_parameters"/>
<operator activated="true" class="text:tokenize" compatibility="5.0.7" expanded="true" height="60" name="Tokenize" width="90" x="202" y="41"/>
<operator activated="true" class="text:extract_length" compatibility="5.0.7" expanded="true" height="60" name="Extract Length" width="90" x="112" y="165"/>
<operator activated="true" class="text:extract_token_number" compatibility="5.0.7" expanded="true" height="60" name="Extract Token Number" width="90" x="246" y="165"/>
<connect from_op="Get Page" from_port="output" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Extract Length" to_port="document"/>
<connect from_op="Extract Length" from_port="document" to_op="Extract Token Number" to_port="document"/>
<connect from_op="Extract Token Number" from_port="document" to_port="result 1"/>
</process>
</process>
