<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process"> <parameter key="logfile" value="%{process_name}.log"/> <parameter key="resultfile" value="%{process_name}.res"/> <process expanded="true" height="522" width="165"> <operator activated="true" class="retrieve" compatibility="5.0.8" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="samples/data/Sonar"/> </operator> <connect from_op="Retrieve" from_port="output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Nov 5, 2010 11:34:48 AM WARNING: Process not attached to a file. Resolving against user directory: '/home/user/process_name.res'.Nov 5, 2010 11:34:48 AM INFO: Loading initial data.Nov 5, 2010 11:34:48 AM INFO: Process //Local/logtest startsNov 5, 2010 11:34:48 AM WARNING: Using deprecated example set stream version 1Nov 5, 2010 11:34:49 AM INFO: Saving results.Nov 5, 2010 11:34:49 AM INFO: Process //Local/logtest finished successfully after 0 s
