In the "Loop" operator description it says:
| The output of each nested operator is the input for the following one, the output of the last inner operator will be the input for the first child in the next iteration. The output of the last operator in the last iteration will be the output of this operator. |
while when I use it to do iterated splittings, the input is always the same for each iteration.
My purpose is just to split a data set into subset1 and 2 and then split subset1 into subset 3 and 4 and so on. The code is here:
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" expanded="true" name="Process">
<process expanded="true" height="521" width="820">
<operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="45" y="75"/>
<operator activated="true" class="loop" expanded="true" height="76" name="Loop" width="90" x="179" y="120">
<parameter key="iterations" value="2"/>
<process expanded="true" height="488" width="877">
<operator activated="true" class="split_data" expanded="true" height="76" name="Split Data" width="90" x="112" y="120">
<enumeration key="partitions">
<parameter key="ratio" value="0.6"/>
<parameter key="ratio" value="0.4"/>
</enumeration>
<connect from_port="input 1" to_op="Split Data" to_port="example set"/>
<connect from_op="Split Data" from_port="partition 1" to_port="output 1"/>
<portSpacing port="source_input 1" spacing="90"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<connect from_op="Generate Data" from_port="output" to_op="Loop" to_port="input 1"/>
<connect from_op="Loop" from_port="output 1" to_port="result 1"/>
</process>
</process>
My expectation is that the output in iteration1 is the input of iteration 2 so after 2 iterations the output sample size should be 36=0.6*0.6*100 (100 is the original sample size,0.6 is just a ratio) while it is still 60=0.6*100. Hope I make it clear...Thanks for any help:)
