Hello again,
I found another strange behavoir, for which I hope for explanatioöns from you:
In this workflow I log the performance, generation and feature names of an opmiized feature selection taking always the best 5 attributes. The process should select the best 5 models for the first attribute. For each of the chosen attributes it builds models with any second attribute and so on., is that correct?
What about the results from generation 0?
I assume that RM is loopiing through the attributes to find the top 5 attributes. Why is the log for attribute names giving "?" then? (Maybe it is giving the already chosen attributes, but then they would not match the performance values).
<?xml version="1.0" encoding="UTF-8" standalone="no"?> <process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.11" expanded="true" name="Process"> <process expanded="true" height="179" width="748"> <operator activated="true" class="generate_data" compatibility="5.0.11" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="number_examples" value="300"/> <parameter key="number_of_attributes" value="100"/> </operator> <operator activated="true" class="add_noise" compatibility="5.0.11" expanded="true" height="94" name="Add Noise" width="90" x="179" y="30"> <list key="noise"/> </operator> <operator activated="true" class="discretize_by_user_specification" compatibility="5.0.11" expanded="true" height="94" name="Discretize" width="90" x="313" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="include_special_attributes" value="true"/> <list key="classes"> <parameter key="first" value="0.5"/> <parameter key="last" value="Infinity"/> </list> </operator> <operator activated="true" class="nominal_to_binominal" compatibility="5.0.11" expanded="true" height="94" name="Nominal to Binominal" width="90" x="447" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="optimize_selection" compatibility="5.0.11" expanded="true" height="94" name="Optimize Selection" width="90" x="581" y="30"> <parameter key="generations_without_improval" value="2"/> <parameter key="limit_number_of_generations" value="true"/> <parameter key="keep_best" value="2"/> <parameter key="maximum_number_of_generations" value="5"/> <parameter key="normalize_weights" value="false"/> <process expanded="true" height="715" width="1094"> <operator activated="true" class="multiply" compatibility="5.0.11" expanded="true" height="76" name="Multiply" width="90" x="45" y="30"/> <operator activated="true" class="random_forest" compatibility="5.0.11" expanded="true" height="76" name="Random Forest" width="90" x="179" y="30"> <parameter key="criterion" value="information_gain"/> <parameter key="minimal_gain" value="0.0"/> <parameter key="maximal_depth" value="5"/> </operator> <operator activated="true" class="apply_model" compatibility="5.0.11" expanded="true" height="76" name="Apply Model" width="90" x="313" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="5.0.11" expanded="true" height="76" name="Performance" width="90" x="447" y="30"> <parameter key="f_measure" value="true"/> <parameter key="youden" value="true"/> </operator> <operator activated="true" class="log" compatibility="5.0.11" expanded="true" height="76" name="Log" width="90" x="581" y="30"> <list key="log"> <parameter key="feature_names" value="operator.Optimize Selection.value.feature_names"/> <parameter key="generation" value="operator.Optimize Selection.value.generation"/> <parameter key="accuracy" value="operator.Performance.value.accuracy"/> <parameter key="f_measure" value="operator.Performance.value.f_measure"/> <parameter key="youden" value="operator.Performance.value.youden"/> </list> </operator> <connect from_port="example set" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Random Forest" to_port="training set"/> <connect from_op="Random Forest" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Random Forest" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="performance"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Add Noise" to_port="example set input"/> <connect from_op="Add Noise" from_port="example set output" to_op="Discretize" to_port="example set input"/> <connect from_op="Discretize" from_port="example set output" to_op="Nominal to Binominal" to_port="example set input"/> <connect from_op="Nominal to Binominal" from_port="example set output" to_op="Optimize Selection" to_port="example set in"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> </process>
Best,
Markus
