Non-Linear Analysis, Hyper-elastic Material.
It concerns the Non-Linear analysis examination, and to be more specific quizz 5 concerning the Hyper-elastic material, I've done the analysis multiple times, I even got the same results of von mises strain as the one shown in the pdf by the instructors, I took my first attempt of the quizz, the problem was that the first question had answers way above what I got in my multiple analysis, answers of 1000 order and above, but when we perform the anaysis the maximum we get for what is asked in the first question is 5.034e+2, what's really strange is that the question 3 and 4 I found the answers just as the one resulting from my analysis, I failed my attempt because I believe the first question should be updated since the second and third are correct. Note tat I'm not the first one to go through this issue, I've encountered another person who went through the same problem and it costed him all his three attempst of the quizz.
Can any moderator please do that particular analysis and actually compare the results with the answers of question 1 and see that there should be an update of the questions. Looking forward to actually get a response this time because I already wrote on the issue and sadly got no answer, I've paused my examination until I get a response, Thank you.
PS: I'm working with the 2022 version, but still I dont believe that the difference of versions can give such a huge difference in results.
Quiz 5 and Quiz 9 have been deactivated to check, you can proceed with the course
