multiply problem
truepen
Dear Sir,
I would like to scramble label value of all data.
As I use the code as follows, I found changed a1 value compared with the original.
If I replace 'multiply' by using copyed 'Retrieve' item, it is correct.
please help me.
regard,
SK
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.0.10" expanded="true" name="Process">
<process expanded="true" height="669" width="953">
<operator activated="true" class="retrieve" compatibility="5.0.10" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30">
<parameter key="repository_entry" value="//Samples/data/Polynomial"/>
<operator activated="true" class="multiply" compatibility="5.0.10" expanded="true" height="94" name="Multiply" width="90" x="112" y="75"/>
<operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="Set Role" width="90" x="246" y="75">
<parameter key="name" value="label"/>
<operator activated="true" class="select_attributes" compatibility="5.0.10" expanded="true" height="76" name="Select Attributes" width="90" x="380" y="75">
<parameter key="attributes" value="a1|a2|a3|a4|a5"/>
<operator activated="true" class="generate_id" compatibility="5.0.10" expanded="true" height="76" name="Generate ID" width="90" x="514" y="75"/>
<operator activated="true" class="set_macro" compatibility="5.0.10" expanded="true" height="76" name="Set Macro" width="90" x="112" y="210">
<parameter key="macro" value="seed"/>
<parameter key="value" value="2000"/>
<operator activated="true" class="select_attributes" compatibility="5.0.10" expanded="true" height="76" name="Select Attributes (2)" width="90" x="246" y="165">
<parameter key="attributes" value="label"/>
<operator activated="true" class="shuffle" compatibility="5.0.10" expanded="true" height="76" name="Shuffle" width="90" x="380" y="165">
<parameter key="use_local_random_seed" value="true"/>
<operator activated="true" class="generate_id" compatibility="5.0.10" expanded="true" height="76" name="Generate ID (2)" width="90" x="514" y="165"/>
<operator activated="true" class="join" compatibility="5.0.10" expanded="true" height="76" name="Join" width="90" x="648" y="75">
<parameter key="remove_double_attributes" value="false"/>
<operator activated="true" class="select_attributes" compatibility="5.0.10" expanded="true" height="76" name="Select Attributes (3)" width="90" x="715" y="165">
<parameter key="attributes" value="a1|a2|a3|a4|a5|label"/>
<operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="Set Role (2)" width="90" x="849" y="75">
<connect from_op="Retrieve" from_port="output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Set Role" to_port="example set input"/>
<connect from_op="Multiply" from_port="output 2" to_op="Set Macro" to_port="through 1"/>
<connect from_op="Set Role" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Join" to_port="left"/>
<connect from_op="Set Macro" from_port="through 1" to_op="Select Attributes (2)" to_port="example set input"/>
<connect from_op="Select Attributes (2)" from_port="example set output" to_op="Shuffle" to_port="example set input"/>
<connect from_op="Shuffle" from_port="example set output" to_op="Generate ID (2)" to_port="example set input"/>
<connect from_op="Generate ID (2)" from_port="example set output" to_op="Join" to_port="right"/>
<connect from_op="Join" from_port="join" to_op="Select Attributes (3)" to_port="example set input"/>
<connect from_op="Select Attributes (3)" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/>
<connect from_op="Set Role (2)" from_port="example set output" to_port="result 1"/>
</process>
</process>
land
actually a Multiply does not really copy the data, but the view on the data. If you change the data values, they are changed in the underlying memory and hence changed in both views.
A solution is as you wrote loading it twice or using a Materialize to write the data of a view into memory.
Greetings,
Sebastian
