Howto: Classification via Multi response linear regression.
I have a classification problem. Instead of a model which tells me the most probable class of a sample i would like to have a model which tells me the chances the current sample has of being of each possible class.
This means that the labeled examples should have, instead of a column containing the given prediction, an additional column for each class containing a real value between 0 and 1 which approximate the likeliness the sample has of being of such class.
In the Weka community i'm told this is called "Classification using multi response linear regression" (or at least that MLR is the best or most common way to do that) and that the Weka component ClassificationViaRegression does exactly that but I didn't found such component in RapidMiner even if it does indeed contains most Weka components. I tried several components in RM for linear regression but all requires a single numerical label instead of my available nominal label, most probably because these do not support multi respose.
Could you please tell me:
1- If the above mentioned component or Weka is available in RM and where i can find it.
2- If there are other component which does a similar thing (maybe even better).
3- If there are other approaches to solve the problem in a similar way which you believe may work nicely.
4- In case there aren't component which supports MLR natively, something (a guide, a tutorial, an example) about how to use single response linear regression components to approximate MLR in RapidMiner.
Thank you.
